Hi guys I'm currently on my P2s with no record of any fines, accidents or anything, I have just bought a manual skyline, but only have me auto license (have my manuals booked early next month), if I drive around in the manual non-turbo factory standard non-eye catching skyline, will I get pulled over and get license inspected, lose my license and get a massive fine for driving without a manual license? Will they ban me from driving forever and cancel my manuals test next month too? And will they confiscate my car since I'm unlicensed to drive a manual on the spot?
Reason is, I'm really keen to drive my new car that I bought as it is the first one for me but I can't wait for me to pass the manuals test next month, what do you guys reckon?
Put up some green Ps and drive it like no tomorrow?
Be good and put up some Ls and only drive it with licensed drivers?
https://www.sau.com.au/forums/topic/357011-auto-manual-licensing/
  • Replies 54
How long is a piece of string?
You take the gamble, it's illegal and it's your license.
Past history counts for nothing realistically. Behave, it's only a month. Better to do it right as if you lose 3 demerits, you are on eggshells for the next 12 months and any offence will see you losing license. (not sure if you do accrue points for it, ring VicRoads).
Yes its a new car etc, but the urge to drive it - just wait. You'll have 7 days and 24hrs to do so once you get your manual license.
This.
Ah, same boat I'm in. Except mine hasn't arrived yet. Over the sea somewhere...:( But should be close to Aus by now, surely...
But I digress.
Aaanyhow, I think the fine is ~$110 with 0 points if you get caught.
But I've also heard stories of like mate's mate's (so really dunno how reliable this is); being not allowed to drive home from where he was caught lols. Then there's always the chance they won't even notice.
Really it's up to you if you want to take the risk. I need to book mine soon as well; and I know I'd be tempted to drive if I had mine here while waiting for my test...but you know. I doubt you really wanna get dicked when the test is less than a month away :/
I don't know if you're trolling me, but I'm a male and you shouldn't make assumptions like that.
Just having a bit of a lend of you champ... :nyaanyaa:
Questions like this come up every few months... ...it's either wait until you go and pass your manual licence or get your manual licence in the first place... ...It's a choice you've made, and, well, you've now got to stick with it... >_<
Yeah I wanted to get manuals but my parents were like no no manuals, auto please auto...since they were paying for my lessons I have no choice. Now that I've got a car, I need to start learning again, though it's mainly changing gears and stuff, road conditions, control etc I'm cool with to pass the test.
happened to me once about 3 years ago now.. i got a $200 fine. no points. with the laws today i wouldn't risk it since people have started to cop points in defects now...
for what?
Officers discretion hamish. If they feel you're too much of an asshole to them or if it's repeat offence or really... For any reason at all because the officer says so, you can also cop points. officer discretion is a wonderful thing isn't it? Just like my major defect for what's usually a minor. Vicroads can't do shit...only way you get out of an officer discretionary punishment is if you can make the officer change their mind...
Yeah right
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
