Hi guys I'm currently on my P2s with no record of any fines, accidents or anything, I have just bought a manual skyline, but only have me auto license (have my manuals booked early next month), if I drive around in the manual non-turbo factory standard non-eye catching skyline, will I get pulled over and get license inspected, lose my license and get a massive fine for driving without a manual license? Will they ban me from driving forever and cancel my manuals test next month too? And will they confiscate my car since I'm unlicensed to drive a manual on the spot?
Reason is, I'm really keen to drive my new car that I bought as it is the first one for me but I can't wait for me to pass the manuals test next month, what do you guys reckon?
Put up some green Ps and drive it like no tomorrow?
Be good and put up some Ls and only drive it with licensed drivers?
https://www.sau.com.au/forums/topic/357011-auto-manual-licensing/
  • Replies 54
How long is a piece of string?
You take the gamble, it's illegal and it's your license.
Past history counts for nothing realistically. Behave, it's only a month. Better to do it right as if you lose 3 demerits, you are on eggshells for the next 12 months and any offence will see you losing license. (not sure if you do accrue points for it, ring VicRoads).
Yes its a new car etc, but the urge to drive it - just wait. You'll have 7 days and 24hrs to do so once you get your manual license.
This.
Ah, same boat I'm in. Except mine hasn't arrived yet. Over the sea somewhere...:( But should be close to Aus by now, surely...
But I digress.
Aaanyhow, I think the fine is ~$110 with 0 points if you get caught.
But I've also heard stories of like mate's mate's (so really dunno how reliable this is); being not allowed to drive home from where he was caught lols. Then there's always the chance they won't even notice.
Really it's up to you if you want to take the risk. I need to book mine soon as well; and I know I'd be tempted to drive if I had mine here while waiting for my test...but you know. I doubt you really wanna get dicked when the test is less than a month away :/
I don't know if you're trolling me, but I'm a male and you shouldn't make assumptions like that.
Just having a bit of a lend of you champ... :nyaanyaa:
Questions like this come up every few months... ...it's either wait until you go and pass your manual licence or get your manual licence in the first place... ...It's a choice you've made, and, well, you've now got to stick with it... >_<
Yeah I wanted to get manuals but my parents were like no no manuals, auto please auto...since they were paying for my lessons I have no choice. Now that I've got a car, I need to start learning again, though it's mainly changing gears and stuff, road conditions, control etc I'm cool with to pass the test.
happened to me once about 3 years ago now.. i got a $200 fine. no points. with the laws today i wouldn't risk it since people have started to cop points in defects now...
for what?
Officers discretion hamish. If they feel you're too much of an asshole to them or if it's repeat offence or really... For any reason at all because the officer says so, you can also cop points. officer discretion is a wonderful thing isn't it? Just like my major defect for what's usually a minor. Vicroads can't do shit...only way you get out of an officer discretionary punishment is if you can make the officer change their mind...
Yeah right
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
