Hi just about to start building my engine, one of the stock pistons gave away because of some overboosting problems with the stock twins. Bought some GT2871R(GT2860-10) Turbos and just ordered some stuff to build the engine.
here is what i ordered, will add engine build pics once everything arrives.
CP Piston Set with Rings // 86.5mm(0.02")
Eagle H-Beam Connecting // ARP custom age 625 series bolts
Nissan N1 Oil Pump
Tomei Combination Kit (1.2mm Thick, 87mm Bore)
・Metal Head gasket
・Metal Throttle Gasket
・Metal Intake Manifold Gasket
・Metal exhaust Manifold Gasket
・Oil gallery orifice
ACL Race Series Con Rod Bearings
ACL Race Series Main Bearings // Standard Oil clearence
ARP Head Stud Kit
ACL Race Series Camshaft/Thrust Bearings & Small End Bushes
Nitto Oil Pump collar
Mods
. Twin GT2871R // ported stock manifolds and ported exhaust housing to match
. Kakimoto 3.5" full exhaust system
. Exedy Twin plate clutch
. Greddy FMIC and pipes
. VEMS Standalone - not installed yet
. Deatschwerks 870cc Injectors - not installed
. HKS EVC 5 Boost controller
. Zeitronix Wideband + EGT
. 2x Blitz bov´s
. N1 Waterpump
. HKS Kevlar Cambelt
. Nismo Oil cap
. Nismo Radiator cap 1,3 Bar
. Nismo engine and transmission mounts
. NGK iridium sparkplugs
. Nismo transmission mount
. Driftworks upper links
. Defi Watertemp gauge
. Full Roll cage
. Apexi coil-overs
. TBO Bodykit
. Abbey Motorsports valve covers
. Volk racing 17x9" wheels
. Xenon Headlights 8500L diamond white
Pics of the car
skyline853-1.jpg?t=1288148474
The turbos and ported manifolds
GarrettGT2871R.jpg?1286908043
and the piston that got wrecked
https://www.sau.com.au/forums/topic/357143-tbo-r32-gt-r-iceland/
-10 turbos on stock capacity or u going bigger?
keeping it 2.6 ltr, not to concerned with lag since at first i planned on using a GT4202, 74mm Turbo with a T6 1.15 A/R. Also had a Supra with a precision billet 42-71mm turbo so im used to a bit of lag
The hotside was bit too big and i decided to go with the GT2871R turbos instead, but here are pics of the GT4202 // just put it up there to see what kind of space i was working with lol
harfeni140-1.jpg?t=1300391373
harfeni138-1.jpg?t=1300391377
harfeni137-1.jpg?t=1300391375
and here is the Supra
MySupraEnginebay2-1.jpg?t=1300391752
Edited by R32GTR/Iceland
  • 4 weeks later...
a little update , the stuff that i ordered is finally here. Just have to wait for the block to be bored and then i can start assembling everything :)
here is what came in the package
Eagle H-Beam Connecting rods // ARP 2000 fasteners
Nissan N1 Oil Pump
Tomei Combination Kit comes with
*Metal Head gasket(1.2mm Thick, 87mm Bore)
*Metal Throttle Gasket
*Metal Intake Manifold Gasket
*Metal exhaust Manifold Gasket
*Oil gallery orifice
ARP Head Stud Kit
2x- Nissan OEM Cam Seal for RB26DETT
Nissan Rear Main Seal for RB26DETT
shitty phone pics hehe but always fun to open these kind of packages
skyline639871234_6887645_3246471_n.jpg?t=1302730101
skyline639871234_6887622_7881410_n.jpg?t=1302730099
skyline_639871234_6887608_6478537_n.jpg?t=1302730102
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
