is there nay reason why a r34 getrag gearbox wont fit into a r33 gtr?
Edit: just found the nismo conversion site. http://www.nismo.co.jp/en/products/competition/mission/getrag.html, has anyone tryed this? though it i could locate a box for a reasonable price it might be cheaper that a PPG or OS giken options
Edited by fomby639
https://www.sau.com.au/forums/topic/357218-r34-gtr-getrag-into-r33-gtr/
there is no reason, you will have to get the original cross member for the getrag ,the R34 rear tailshaft and the front tail shaft as the getrag is 20mm longer than a 5 speed.. it will bolt straight in, You use the R33 speedo drive it will work but the speedo will be reading incorrectly as the gearing in the R34 in higher.
sorta related. I was considering dropping one of these boxes into a R32 GTS4.
given that there are several things different about them vs the old 5sp I have
what needs to change in order to fit one to a 32 chassis
I know that:
32 has cable speedo drive
driveshafts are probably the wrong length
clutch is reversed.
unsure of:
ATESSA setup (34 vs 32)
rear crossmember mounting points
anyone done this?
Getrag 3.83:1
5 speed 3.214:1
Keep in mind that is just a quick search my mobile. Running 4.375:1 diffs in my car as well, so know how short first is already.
do you have a 6 spd in yours by chance? if so does the shift hole line up? ( I have just bought a full interior for my car and I'm not about to chop that up..)
No, currently have an old r32 spec 5 speed totally missing 3rd-4th synchro, with the gts4 4.375:1 diff ratios front and rear.
Have a brand new ser3 r33 box waiting to go in on monday so will finally get to experience what everyone else takes for granted (my gearbox was on its last legs when I bought it over 4 years ago).
I can't think of any reason why you would want to fit the 6 speed instead. 5th is the same as 4th in the 5 speed (ie 1:1), and the overdrive is about the same so you don't gain longer legs for distance driving. Just have to shift more often.
A bit better search revealed:
getrag ratios
1st 3.827
2nd 2.360
3rd 1.685
4th 1.312
5th 1.000
6th 0.793
r32/33
1st 3.214
2nd 1.925
3rd 1.302
4th 1.000
5th 0.752
Knock everything into a gearing calculator like this one http://www.boosttown.com/gearbox_differential/speed_calculator.php and see what you get. The getrag with 4.11's is shorter than the 5 speed with 4.375's.
Fitting a getrag was a fleeting thought, but the hassle and extra expense to end up with something that is a curiousity was not justified.
My mate did this in my shed a while a go.
It's possible but you will have to massage the firewall and gearbox tunnel.
We had a hoist, a hammer or two and around 4 blokes to fit it in coz I did not have a gearbox jack atm.
so how did it behave?
whilst I see the numbers above (and they make sense) what rpm are you doing at 100kmh?
ideally I would like to see mine at 2500ish in 6th. the idea I haev is a quick street car with highway driveability. current subaru with 4.44 rear/front diffs does it at 2800 with a 4spd auto.)
You could change to Stagea diffs (4.08:1 about the same as GTR at 4.1) to reduce your cruising revs. R34 GTR is 3.545:1 possibly a bit tall for you without a massive power increase (rb30/26 conversion!).
You have Subaru 4.44 ratios in your GTS4?? How did you manage to make them fit??
  • 2 years later...
Did you end up going this way ?
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
