Also no one else in perth has the english software to tune it
(i can get you the Japanese one no problem but then good luck trying to tune it),
so you will only be able to use Xspeed
Can you get english version of 3.1 PW?
You must be joking. On the CD's in Japan Yahoo auction you can get only 3.23en and 3.241en.
To have 3.1 in english you have to do it yourself and I have done it.
So your claim that no one oi perth has got it is false.
but can you tune the ecu?
my point is no other tuner in perth has the software + cable to do. so yes you may be able to get the software in english but without the cable it is useless.
its not impossible to get the software + cable and from what i have seen is not that pricey compare to the pfc dongle unit. However for some reason tuners here in perth (and also looks like australia wide) don't seem to want to tune them (not sure if it has something to do with hks and rumours that they only want hks dealers to tune their ecu)
Edited by Kaido_RR
From what I have seen, the software is Japanese for that version, not hard to tune if you are familiar with the menu structure... Not something a reputable tuner would go doing though.
I will only ever run an ecu that I can adjust, and anybody I choose, that's why the HKS is worth nothing here.
btw Ten Four buy the hks nav, just like the pfc h/c
http://www.sw20.jp/20/Tech_Articles/HKS_F-Con_V-Pro/Navigator_Pro.html
edit: also give this website a read some good info regarding the f-con pro
http://www.sw20.jp/20/Tech_Articles/HKS_F-Con_V-Pro/HKS_V-Pro.html
Edited by Kaido_RR
Kaido, I have cable as well.
Yes, it is in Japanese but all 15 versions of HKS PW done in English as well, full 100% done.
Cable is not a problem to make it yourself.
Tuning? I know a few people who did it them-self without any problems.
In Uk and Russia so it can be done in Au as well.
Its so easy if you have software PW in English.
Edited by jan25
i am correct in saying the f-con is unlike the pfc were you need a dongle. the hks just uses a cable correct?
Correct, what you need is only cable and password which is 100% in the ECU from Japan, if want want to base on existing tune
and not the resetting to start fresh tune. We can read password remotly without sending the ECU to us.
Correct, they want only their authorised dealers to sell and tune the F-Con ECU's.
Would personally rip it out, screw only being able to take it to one tuner
previously ran the Fcon Pro in my 33. all i can say is that its an amazing piece of hardware. youre questioning its quality, but you dont seem to reason with why big workshops like Top Secret and HKS run them in there drag, demp and drift cars
yeah as the other have said the FCON is great
for a standard FCON install its a piggyback setup so you need to buy the FCON, the harness and then the navigator and its still connected in piggyback mode
this is why most go for the powerfc as its a simple plug and play, no extra controller, no harness needed
FCON in piggyback mode is fantastic for auto but very pricey vs nistune etc
for the FCON standalone the unit is more expensive, i think the loom harness is still needed and the navigator and the FCON pro vs FCON normal (piggyback one) is pricier
i would love one to try it out
32x32maps
afm or map
inputs from whatever you like
Turns out it was a FCON 3.0
$1600 tune ffs. So f**king poor now. (Thats cash too)
Car made 400rwhp at 20psi - unknown turbos.
Curious as to what the power and torque curves look like compared to my PFC tune on similar mods. Do you have pics of dyno sheet? ph34r.gif
why do you expect or believe the FCON would make more power?
i see no reason why the FCON would make more torque or more power (or less)
if both are tuned correctly you should get the same result
the main difference is how long it would take the tuner with both systems
I never said that.
I was merely complaining at cost of the tune.
Get to take it home tomorrow :)
Will post up then in the RB26 power section.
Would love Andy to tune it... but not happening anytime soon now lol. (HOPEFULLY)
Wondering if anyone here is running this?
I have one and because WA is ghey, only one place can tune it and I'm quoted $1500 - 8-9hrs dyno time =/
I'm in a pickle really, its booked in still to go ahead, but considering my options atm...
New Jetro is $2k + tune 500? + install ??
2nd hand non jetro = 1k? + 2 AFMs $500?? + tune 500? + install ??
Are the HKS F-CONs worth it? Just can't believe the cost to tune... There goes my next month and a halfs pay...
Hey brutha, saw your 32 in xspeed the other day when mine was on the dyno - love your plates and I'm glad you own a gun metal like me (although mine's a GTST).
They will absolutely rape you on tuning for anything other than Power FC dude. I asked about Haltech and HKS F Con Pro and well, lets just say Hanson said "if you don't use power FC you will be up for thousands. A full tune with a PFC is about $750 at X speed providing there aren't major issues to overcome.
Get a PFC dude - at least they still make em for the gtr. I have to suss mine secondhand...
Hai der. Collected it today :)
I've had good experience with PFCs mate but as said before, cost of tune < Power FC + tune...
Mods can close thread if they wish!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
