I have been seeing an increase in skylines in the area and thought It might not be a bad idea to see who's about and what they are doing with there car's.
So list it out like this:
Car: 1992 R32 GTST.
Colour: White with black boot and bonnet.
Mods:Pod, Exhaust, Coilpacks, FMIC, Nistune.
Plans for the next Mods: Turbo and Injectors
Owned for: 8 months
Any other imports(this can be current or previously owned): R33 GTST 300zx TT
anything else you can think of feel free to add, Wouldn't mind getting a north area cruise group happening or even a meet and greet.
Yeah man I have a r32 gtr silver no. Plates is slo26 but I live in kallangur mods r twin t517z kls low mount manifolds 3.5 inch dumps PFC 740cc injectors splitfire coils sard fuel pressure reg denso pump twin z32 afm boost 2 twin plate osgiken clutch the only problem is there's a noise in the head maybe bent valves so that's what's next on the list can't wait to get it fixed then I'll have the 300awkw monster back on the road
we just purchased an 1993 R33 GTS25T 4 door turbo
its silver and auto (missus cant drive a manual and it will be somewhat of a daily for her)
getting it rego'd next week
its stock as a rock except a turbo timer
even has the factory casette deck and an air purifier in the parcel shelf!!
we are at Narangba
I drive a 1990 MX83 cressida with a 1jz in it
its also silver with a big PWR front mount hanging out the front
has big single turbo running 18psi and a 3k high stall auto (going to manual as soon as I can afford it) 3" exhaust with twin 3" pipes(drift style)
good fun suprising the kids around here haha
I live in the north as well and own a wine red R32 GTS-T. I Have owned this car for about 10 years nows. I just can't let go.
Mods - PWR radiator, GTR Injectors, z32 afm, Bosch 040, Returned ecu, HKS GT-RS turbo, Tein SS Jap spec suspension with EDFC, cusco LSD 2-way.
Engine is healthy but is leaking oil out of tapet covers again Grrr.
Car make a fare amount of power at 23psi but I have never dynoed it to get the true rwkws reading.
I will be getting a new EBC and nistune very shortly and next year maybe sway-bars and cams.
Edited by RedDrifter
we are at Narangba
Nice R33 is a good choice my missus wants one because I used to have one and she loved it.
I want to see this cressida it sounds badass
the cressida is pretty ordinary in the looks department
but it goes ok
need to get an aftermarket computer for it to really tap its potential
just picked up a set of Bigwin side skirts and rear bar for it today just need to get them repaired (has some damage) and need a front bar
all in good time.
The skyline will get the usual mods once its registered and just replace things as they break
Welcome to the thread, That turbo is some seriously expensive kit man, How does it perform?
but it goes ok
all in good time.
Looks are not everything. I am planning on doing a sleeper as my next car.
I bought the kit from Nengun 4 years ago when the AUD was strong against the yen. Picked the kit up for a real good price.
The turbo is as big as you would want to go for a street RB20.
Response vs power output is incredible.
well our skyline should be rego'd on friday woot
started it on the weekend and it made the rattle sound at the front near the timimg belt cover area so i am guessing its in need of a belt/ tensioner/ bearing change from all the youtube and forum reading ive done????
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
