yeah just a normal 1jz not a VVTI
look forward to attending a few events this year,
We were following a silver stock looking R33 4 door with a cannon exhaust this morning going past narangba station,
we were in a white navara with yellow light on the roof so you probably never noticed us
I think it turned down torrens road at petrie
Hey you Northfolk, As of last night we now have a new executive to steer the club over the next 12 months.
We are planing a major upturn in events ans would like as many of you as possible to join in the fun.
We will be doing 4 major cruises a year and one of these will be in your direction. The club would like to hook up with you guys and then move on to the sunny coast and do the same with the skyline fraternity there.
Our first major cruise will be a western swing taking in the flood hit araeas between brisbane and toowoomba where we hope to hook up with as many liners as we can.
The northern loop will be the next mjor cruise after that.
Let us know if you are interested and keen in becoming more involved with an active club.
Cheers, your new pres.
:thumbsup: for sure
Let me know when your open for business. my dash is doing some odd shit at the moment, I either need a auto sparky or a exorcist.
Will do for sure mate. As soon as I know, which I should know next week, i'll let you know.
Cheers guys for the support. Hope I get to work on some/all of your cars, as i would like to make this business the go to place in Morayfield and beyond.
116 any chances of a house visit. I have a 300zx that has no spark and the last guy did the dodgyest job of wiring i have ever seen. PM me if you can with your hourly rate and we can set up a time.
Keep an eye on the events section peeps. Fun times posted up and more to come.
When I had my 33 I used to attend Club cruises but being on the northside we always had to drive a fair way to get in on the fun. The effort to include north liners will not go unnoticed or unappreciated
well I'll kick it off then:
every thursday night at Carsedline central - we have a northside meet. start at 730-8pm till when ever. there are coffee shops/nandos/pizza capers and all are willing to kick in a bit if the meet gets off the ground.
I'll be there at pizza capers this thurs at 730-8pm to start it.
do we have takers?
do we have takers?
im in...but where the hell is carseldine central?? carseldine sounds good to me. easy to get to. and all highway!!
*never mind...found it..lol will be there i recon.
Edited by boiracer
its on the corner of Beams Road and Gympie Road
heading out bound its on the left
inbound its on the right
it is at the last set of traffic lights before the Bruce Highway starts
if your retarded the 1st exit isnt far up the road so a U turn is easy
Maybe able to swing out and have a looky. Not a bad spot. Plenty of parking up and underground.
As for the Harry's meets, the cops aren't as bad as they were. Been their plenty of times and they are a good bunch of guys. Last time I was their a 32 rocked up with straight through exhaust, 1 headlight working and slamed on it's nuts. A copper a guided him into the park and said nice ride. I kid you not. I spoke to him about there presents there and he basically said they were just to keep things under control and stop the dickheads. You still get some dickheads, but thats most places you go. You'd be very suprised how they turn a blind eye to the cars that rock up their. Another one, this guy had a Merc pretty much on bump stops and the copper goes, didn't you have another 1 the other week or was that someone else. Couldn't belive what I heard.
The coppers down there from what I hear are pretty good, However they did turn up just after we left because people forgot how to use a sidewalk and also how to exit a driveway without leaving rubber flavored momento's behind
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
