Dunno if im barging in on anything, but i've had a 32 gtst for a few months now... Keen to cruise with the locals as im in Rothwell....
On a brighter note, I was in Peninsula paint today n "saved" some poor sod who thought he blew his turbo on a twin turbo supra.... Turns out he should check his intercooler piping more often.. Fished out the slipped hose clamp and with a trusty 10mm I never go anywhere without, saved him a trip to the workshop. Wish all my mechanical problems were that cheap or easy :)
Im Troy by the way. If anyone filled up at the caltex on deception bay road just up from the rothwell roundabout, chances are we've already met
Hey Troy. Welcome. My missus just works behind you at the child care centre and owns a marine blue 33 4 door. I have a white 32 4 door. I know the owner of the servo for years and years. Top bloke. One night boys I will organise a meet, just been very sick lately and haven't had much time of a night to hang around. Hang in there as it will happen I promise.
spotted Brad in the 32 4 door heading up Buchananans Rd. just now. nice clean looking car :thumbsup:
finally got the new engine in the little ladies Beetle. once its run in and tweaked properly I'll have the liner back in my hands more permanently.
Wednesday at the BP's sounds good this week. but i think we should give somewhere around northlakes a go maybe?? should be parking and some eats there somewhere. gonna look into a good spot some time soon...when i get a moment to think in between doing stuff.
clean is the under statement of the century... :D
its (ummmmm cant find the words) super duper clean...
Ultra shiny?
I have badly damaged my back so someone is going to have to drive me on wendsday night. (I can barely limp atm)
for sure.
ive done many a large amount of Body work in my time, but the older brother is normally the one swinging the spray gun when we paint cars......but hes in Wagga atm doing his military thing...soo chances are that wont happen for a while anyways.
What were you in???? I have morning face on and everything is a blur. Some mornings I don't know how I got to work lol. So if you had waved I apologise man. I have seen a black 32 coupe along the same road every morning. Very clean as well.
LOL Col. I'm a clean freak YES. Bit pissed off with the rain this week. Made the car look rather shitty. Spent close to 3 hours cleaning it this morning.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
