Hey guys been awhile.
Nothing new to car as of yet:(
House got finished finally so been pretty busy, would like to catchup b4 xmas but doing long shifts nxt week.
Bodo ill drop by sometime and say hi?
Good to hear man. Yeah some time soon. Gimmee a call or message at some point, as I have lost you number in a phone swap. :)
Can anyone google map some good spots for a photo shoot around the northside/city?
Been a tog for a while but never played much with automotive, wouldn't mind photographing other member cars as well if there is interest.
Always wanted to get a good shot of skylines in all the lanes on the ICB tunnel. :D
photos would be good, but as for locations....i got no idea. :(
no time for drinks sorry ash....atm it looks like i'll be working saturday, my bro is coming up from Newcastle on sunday for drinks, and my family does christmas on Christmas eve.......and im already dead to the world.
ill have time between Xmas and new year :) we should get that gear knob of yours sorted in that time
Alright seems a bit of interest I will post up a thread in the New Year to get a shoot happening.
Carparks are good for still shots, idea's? Germside?
Somewhere we can get the city in the background at night would be great, any ideas?
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
