tones Posted March 15, 2011 Share Posted March 15, 2011 Just wondering if anyone could tell me what is the difference between r32 gtst (sumitomo) and r32 gtr/ 33 gtst calipers to allow the larger discs? I did do a search but had no luck. I know you can get a spacer to allow the larger disc with the 32gtst ones but I was trying to avoid spacers and they seem pretty pricey for what they are. Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/ Share on other sites More sharing options...
Russman Posted March 16, 2011 Share Posted March 16, 2011 The legs where it bolts to the hub are longer to accomodate the larger rotor. They can be found pretty cheap. Simple upgrade. Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-5717021 Share on other sites More sharing options...
Beer Baron Posted March 16, 2011 Share Posted March 16, 2011 yeah the caliper mount lugs are different. obviously the GTR ones are longer so accommodate the 296mm rotor over the GTST 280mm rotor. getting a spacer to convert from 280mm to 296mm is not so great as it's only an 8mm change in radius, so since the spacer is so short you have to offset the caliper. my advice is either get 32 GTR calipers (pretty cheap) and run the 296mm rotors, or keep your GTST calipers and get the caliper spacer to run R33 GTR 324mm rotors. that is a nicer upgrade with a rotor that is quite a bit bigger than the GTST rotor. Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-5717385 Share on other sites More sharing options...
tones Posted March 17, 2011 Author Share Posted March 17, 2011 Thanks guys, I'm just going to purchase some gtr calipers and discs. Just out of curiousity what's around in the way of parts to rebuild calipers? Are pistons and seals available and at what sort of prices? Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-5718577 Share on other sites More sharing options...
Beer Baron Posted March 22, 2011 Share Posted March 22, 2011 yeah pistons and seals available from nissan. you can get a rebuild kit which is seals and dust boots pretty cheap. alternatively buy the project mu 32 GTR rebuild kit. it comes with nice alloy pistons which are lighter and a seal kit too. from memory it's around $400 for the full kit (includes 8 pistons). it's good value and will mean your calipers will be like brand new again for $400 and a few hours work. Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-5725215 Share on other sites More sharing options...
tones Posted March 23, 2011 Author Share Posted March 23, 2011 Thanks mate, that project mu kit sounds like a pretty good deal, will look into it Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-5727496 Share on other sites More sharing options...
masTers Posted November 18, 2013 Share Posted November 18, 2013 Is there a way to tell if I have 32 GTST Caliper or 32 GTR calipers? Just a simple measurement to something? Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-7112027 Share on other sites More sharing options...
niZmO_Man Posted November 18, 2013 Share Posted November 18, 2013 GTS-t calipers have ribbing on them, GT-R ones are smooth. Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-7112776 Share on other sites More sharing options...
GTSBoy Posted November 19, 2013 Share Posted November 19, 2013 Good reason to not use R32 GTSt calipers for anything is that they all seem to be creaky and flexible. Even though all these calipers look more or less the same, the GTR ones and the R33+ ones don't seem to flex the same as the R32 ones do. Link to comment https://www.sau.com.au/forums/topic/357586-r32-brake-calipers/#findComment-7113392 Share on other sites More sharing options...
