  • Replies 184
Posted Images
Was thinking of using that on the roof lining atleast
But main aim is to get it road worthy and engineered. which means getting this motor finished
Block was just dropped off at the machinists for an acid bath, all welsh plugs and gallery plugs are being removed. Then we'll check the piston to bore clerance to ensure the stock pistons are still fine in the bore
If not, i'll have to try the other 2 blocks i have
The 10mm foam won't fit in the roof, needs to be 5mm. I learnt this the hard way and it made the clips at the back near the rear window separate from the lining after a few days. I think I've got enough of the 5 mm left over at home. If I do it's yours.
Try out the foam I used on top of the dynamat Chris, weighs nothing and makes a big difference.......just my 2c
Whats the "foam" you refer too champ? Any pics to what you are talking about? :unsure:
Bit of progress :)
Always hated how unsecure the front bar was, dealing with bolts into the guards and spacers between the lights. This basically allowed alot of movement when driving leading to rattles etc.
As you can see below im working on a new reo for the bar, tied into the 8mm plate steel mounts for the intercooler.
So in order to secure the front bar in a way that allows for fairly easy removal i made up some mounting points that were attached to the front bar.
Then triangulated some supports to hold it in place while i removed the bar
Then once removed i linked them to the support bars.
then reinstalled the bar to test it out
PERFECT! so sturdy, and just with these 2 mounting points
Next step is to connect the rear of the bar to another support, so this will remove the connection to the front guards.
So to hold it in place until i've finished the new mounts i use the panel clamps i got in my Cleco kit.
Next step will be to work on the intercooler piping on the hot side.
Need to wait until i get some new rollers for my MIG so i can run 0.6mm wire to connect these 2 4inch stainless steel sections into the body work.
I designed them this way as i was cutting through the silicon joiners as they passed through the factory holes, so angled how i need them for better pipework design and a CAI for the airbox i'll build later on.
With everything closed it was time to tackle some of a little jobs that i didnt need materials or tools for.
R34 GTR passenger seat mounts were modded by welding on the stock seats mounts back to the rails.
Also installed the new painted dash to get it back to a more stock look, removing the guage holes and will let me start working on the new guage holder in the DINN area.
next for this area is to mod the gear shift around to hold the ID3 display, then paint it to match.
bottom dash pieces will have to stay out until the RB26 loom and ecu is ready to go in
Another little update, took a while to cut out the shape, but the new holder for the ID3 display is mostly ready.
Just need to work out a mounting option for it, and get some velcro to hold it in place..
Bit more progress today before the work week starts again.
Triangulated up the front bar mounts with tubing, then to test out my new dimple dies we added the plating between the supports.
Next step is to finish welding the supports, then make a new support panel for the new power steering fluid cooler.
I will be working on getting the car running again with the RB25 to test out the all the changes already made to : brakes, fuel system, wiring, intercooler, front bar supports, rear suspension geometry, and the new Tein Flex's i installed earlier (these need to be leveled out after the settling period)
so plenty of things to go yet, but getting close to running again. Dont want to jump too far ahead and have alot of things to tweak when the 26/30 goes in.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
