  • Replies 184
Posted Images
Next:
  1. strip down all the piping and clean up the insides of all the pipes
  2. got my new 0.6 rollers for the MIG and a new gun and lead (currently setup for Alloy MIG welding) - so weld up the pipe pass throughs and finalise the front reo welds
  3. make supports for the rear of the front bar
  4. re-run vacuum hose to the boost controller from the plenum - old setup had nipples on the turbo outlet pipe
  5. make a plug for the Pcv holes in both plenum and cam cover
  6. connect up inlet pipe
  7. start it :P
Well this list is completed and the car is running again.
Just waiting on the pins for the rear calipers to hold the pads in place (custom machined pins due to the spacers inside the caliper) then off to a wheel alignment later this week.
Chris,,,when and if the timings right I would be more than happy to talk about buying your inlet manifold :-).
Cheers
Neil.
No worries Neil :)
Few updates:
one big hiccup, noticed a small amount weeping of coolant weeping from the water outlet in the plenum, so i tightened the hose clamp.............and crack!
whoops
Off to UAS for a replacement and had the new outlet pipe installed in about 20 mins.
In order to attract less attention from the police i have started prepping a street boot that i have shaved over the last couple of nights.
Will get this painted up and installed this week hopefully.
Well, i took the boot around to a painter....
was told that i over heated the panel and stretched it, and that it wont block flat without heat shrinking the boot (granted that it was a little hot and the boot skin does flex more than std) and that i should find a new boot and start with that.
so i went and spent $31 on some acrylic GMH black paint and a spray primer.
primed, dried, wet sanded then gave it a couple of coats of black. just wish the spray gun i had was a little more reliable and would spray a nice consistent pattern, turned out ok, flash certainly makes it look worse.
Will block it again and give another coat later when i can get a better gun, or someone who is a better painter than me to give it a go :)
got the boot installed last night when a mate came around, its not really a one man job.
hopefully get the pins back today, so i can drive the car out and give it a wash :)
Also swapped out my Sard FPR for a nismo item, much neater install now - just a bit fiddly testing the pressure before the swap and after. Just glad my mechanic lent me his guage for a couple of hours for it.
Nismo FPR is super easy to adjust.
Still some troubleshooting to be done, my idle is a bit dicky after 55 degrees water temp, tap the throttle and it idles at 2000rpm. This can be driven out by doing a lap of the block, or by disconnecting the AAC's plug.
Might download the powerFC's map to the laptop and do a reset, then reload the map see if the idle learning procedure makes a difference.
Chris, before resetting the tune, have you put some magic Subaru Upper Cylinder Head treatment through it?
I did mine (Many years back now) by ripping it all apart and scrubbing it blah blah blah... Still had gunk in it... Did the ol' Subaru treatment to it, by spraying the subaru shitdown through the actual AAC valve (You'll need someone to hold the revs up for you as it will cough and splutter like a bitch!)
I'm thinking it might be a gummed up AAC is all...
cheers Daniel, will have to start hunting for them, also need the loom for it too .. sigh lol
hmm Matt, this is different to their in oil treatments? so like a carbie cleaner product?
subaru service centre is just at the front of my complex so might be able to get some today
gave it a run around the complex, handbrake needs adjusting and a wheel alignment big time.. few rattles in my cold side piping as its not permanant.
gave her a rinse too, might try a proper wash tomorrow
going to lower the rear 10mm, that should raise the front the 3mm i need to be legal there.
might also need to get the guards rolled before i correct out all the camber on the rear during the wheel alignment that will hopefully take place later in the week
Yeah it's like a carby cleaner, you spray it in while she's running, throw it down the pipe that leads to The aac valve. It'll wanna stall, you'll beer two people one to keep te revs up the other one to spray.
I think the idle is relearning as its getting better- found that the IAC under the plenum was unplugged lol so fixed that
also adjusted the handbrake so its real loose now to protect the alloy drums.
felt a clicking in the brakes, turned out it was just the master cyl stopper was a bit loose so tightened that up and the brakes feel alot firmer and more touchy than before i swapped to the brembo's
Hopefully the brake shop i use still has the bias testers so i can see what the brakes are doing as i suspect the rears are working harder than the fronts
anyone got a spare r33 gtst series 1 clutch slave cylinder? left leg is too weak for the clutch now lol - get a spare bored out to 20.54mm or similar like the nismo slaves. well if tis cheaper than the $154 i'd pay getting the nismo one shipped over from JPN
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
