  • Replies 390
Posted Images
ahhh john mate seen this beast come allong way...i member the day u droped the q45 in it...f**k it sounded good...good to see its all comin together well...ull have to take me for a spin once the blower and everything is on :) haha...cheers mate...top stuff!!
hahaha yeah for sure rob.
No updates for a while, sorta lost interest and drive for a little while as i had no idea when the computer was coming. But it left yesterday and should be here today. Hopefully fire it up for the first time tomorrow afternoon. Take it down the coast for a tune next week!! now im kinda of excited again.
Rob i got ur PM i will look into that, cheers.
UPDATE:
IT LIVES!! Fired it up last night, built up fuel pressure, turned it over and it idled like factory.. well it hunts a little with the blower and is a little rich... A test drive and some street tuning tonight.. Then a trip down the coast to be dyno'd.... It sounds unreal!!
Can forsee a few small problems with it... the rubber seals where the funny lookin manifold splits may leak.... Still have to put the engine damper on the calm it down... with the blower mounted so far to one side it ends up moving quite a bit, Fuel pump is farken noisy!! but i knew it would be.. mounted on the boot floor that now has no sound deadening..
All thats really left to do is pretty up the interior and do the cage... these are trivial though...
Well everything seemed to work out perfectly. It made 5psi from ~6k through to 7.2k where it just started to max the injectors out at 335hp@rears and stupid amounts of torque... car is very stupid to drive and overall im absolutely stoked... to take it any further id have to put bigger injectors and lower the compression, easy enough done... but it will do "for now"...
it makes progressive boost all the way to redline.
Going out to willowbank tonight for some shake down passes. Getting excited..
First time out on slicks should make things interesting..
ok well all worked out ok... kind of... couldnt manage under a 13 to start with but then we pulled the air cleaner off and played with some tyre pressures and the car dropped almost a second...
it managed a 12.42@112mph with a 1.7 60ft time
It wont change from first to second with out completely back off so it is loosing heaps of time there.. it kept going faster all night but andra kicked it off once it ran under 12.5 cause i didnt have front runners...
So i sourced some front runners yesterday wheels and tyres and they should be here by the end of the week...
Now i just have to sort the gearbox,, we may take it out for some more testing after power cruise before deciding which way we will head with the gearbox...
Options are speak to the guys in the states and send the valve body from the current gearbox over there to be modified, have a custom auto computer built for it and buy a big power handling rebuild kit for it.
And the other option is to make a Fully manualised C4 or turbo 400 bolt up... Either option is going to be really expensive... Im leaning more towards a built turbo 400 as parts seem to be cheaper for them and they are fairly cheap to get a ahold of second hand.
But this still means i will need to modifiy the drive shaft again and get another custom stall convertor built...
And at the moment i have zero cash... just waiting for the GTR to sell and then we'll see where we go from there....
More research is being done into a methanol enrichment system as well.... I want more power.. but first we have to get it down the strip with no headaches..
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
