Sounds pretty damned good.
Sorry to go O/T but could you explain this 12.5 and "front runners" business to me, i briefly looked at the ANDRA regs and found this:
Cars quicker than 12.50 (1/4 mile) using independent front suspension and cross ply rear tyres are not permitted to use radial from tyres."
But I'm afraid i still dont get it. :D
Edited by Oosh
  • Replies 390
Posted Images
ok ummm, basically all modern street cars use steel belted radials (well most) this is where there are steel belts that are formed in the rubber to hold the tyre together, stop it expanding flexing make it stronger basically.
The slicks (crossplys) instead of using steel belts use Use a nylon? or some sort of material to hold them together..
And i havent yet experienced it but when u run faster with crossplys on the back and radials on the front it makes the car very uncontrollable at high speed.
If that makes any sense?
ok found a place that was overly helpful and they are going to perform valve body mods and manualise my gearbox which should hopefully fix the current dramas... this though will not be done untill after power cruise and possibly autosalon...
Matty Spry from pits.
Just wondering whats the address where Mathew Spry works at ( Pits )
Mathew dynoed my car at chip torque about 3 yrs ago , and was happy with the work he did . Now want to get the rb30de sorted ( tuned )
DON
Edited by dondesoto
Hey champ! just read up on some of your post! car sounds nuts... can you get some video footage of it? :)
I myself am doing a VH45 into my R32 GTS... only i'm staying NA.... going 8 throttle/trumpets etc... should be interesting to see the figures these engines can pull!
Keep us updated with your car... 335rwhp at only 5psi is VERY VERY nice power... i can't imagine the torque it must be making... wheelspin heaven :)
Goodluck,
Christian
  • 4 weeks later...
Sounds good mate, good luck with that,
Valve body is in adelaide being modified... car is basically finished bar the roll cage and some interior bits... i have finally got a set of front runners for it. so it should be racing at street car shootout saturday week.
Great read mate!!
C4 will break ... but i'm sure the auto guys have already told you that!
They make too much torque!! Well this is what i was told when i went looking for a box for my VH45
I went for the 2 speed powerglide option. Full manualised valve body and transbrake. With a 3500 rpm stall (With 800 flywheel hp)
Interesting you went the supercharger way ... i just didnt have the room for extractors and twin exhausts in my S12 so i was forced to go turbo (not that it was ever going to be a question anyway)
Once again great read!! Whoever the goose is that said you'll regret the microtech ... obviously has NO IDEA ... i'm running one as well mate :D
The only option if you want big power B)
Well done!! Whats it like owning the only decent R33 in australia? (waits for the response :lol: )
Haha cheers for the reply matey, u got ne pics of your car?? sounds like its gonna be a bit of a weapon.
I get the valve body back on tuesday, aswell as a manualised computer thing... apparently its all electronic in this gearbox... ill be taking it too willowbank if it doesnt rain on wedensday to get a bit more of a feel for it before street car shoot out.
You have a PM mate :)
How much did the valve body set you back?
Well we made some more progress.. The gearbox is in Now shift kitted and full manualised... and let me say this is the fcken coolest sh1t since sliced cucumber......
As soon as u touch the stick it fcken slamns into the next gear in an instant of a second, with this who needs manuals...
Neways the results....
Run 1: Half power pass just to make sure it was gonna change gears. 13.0@111MPH short shifting at 5000rpm ....
Run 2: Got a little ambitios as a stalled the car up and the little 4" front runners slid foward through the beams, when i realised what happed and decided to actually leave the line i ended up runnin a super cool 15second pass.
Run 3: A little more conservative as it was going to be my last run of the night and i just wanted to get a time down. So i staged and waited for the other dude to fcuk off so i had no distractions... Powered her up real slow to just above 2000RPM no where near its ~2800RPM stall point, Side stepped the brake, not used to the gear box i was still slightly short shifting it but not b y much and managed a best time of:
12.2@112MPH
Pretty stoked with that for a number of reasons... Its the fastest Blacky has ever gone... I reclaim my title as the fastest TK Member and There is still plenty of time left in...
But for now and for race day on saturday i wont be trying to get every last second ouot of it, but i will just be trying to get it down the track as consistantly as possible.
After this injectorsr will be pulled out and sent away and turned into 750cc Injectors. I will also be running 50% Pump Fuel and 50% Toluene mix giving a much higher octane then it is back down to the coast to play with pulley sizes (boost) and really start to lean on it... I should excpect to see at least 400 odd ponies at the rear tyres which will definately push the car into the good part of the 11's from there well.... I think thats were phase 3 begins
May not be high flowing the injectors just yet if i can get an off the shelf item that would be heaps better...
Boost, we will probably take it up to 10-12psi for now and just see how it goes and what its going to do if nething....
It also went to streetcar shootout on saturday, made the top 8 out of a 70 odd car field and ran its fastest time to date and i still backed off just after 3/4 track.... 12.243@112mph....
You want a price break down...
If u read earlier in this thread youll see the engine conversion itself cost me around 5g's
to supercharger it with all other supporting bits and pieces ive spent around 12g's on it
Add that to the price of a half decent NA 33 and you have relatively cheap drag car...
Mind you the prices i quote dont include any labour at all.... as i did it all myself with the help of a friend.
EDIT: When u consider the GTR that i recently sold... i spent upwards of 20g's on it to get it to the same power and identical qtr mile time.
I think total your still coming in cheaper then a stock 2nd hand 33GTR and i know which i would prefer.
I cant afford those.
Just dropped off some RB25 Turbo injectors to be highflowed. Should have them back tomorrow morning. Ordering a 205Lt drum of Toluene today and the car is booked in on the dyno Saturday morning... so it will be back out to test and tune, fingers crossed next wedensday.
Getting really REALLY excited now.
Its ~60 bucks each to high flow them
The microtech is a custom made jobbo, with a few extra bits and pieces we wanted for racing. Basically an LT10 with on board ignitors and a few other auxilary inputs and outputs.
We are going to do a few tests next week using the two step rev limiter to get launches more consistant.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
