GDAY , i had all intentions of getting out to the Jamboree , but just .. excuses i wont bore you with them .
Am still interested in the auto box , ph me on 0423 546 380 .
regards
Don
Sorry gave you wrong ph no , its 0413 546 380 or work 32768781 or h 33799091
  • Replies 390
Posted Images
Any video's a good video :laugh:
Here you go John:
http://www.flexi.net.au/~waradsl/ska/john400m.wmv
(right click, save as)
Thanks to LazyBastard for hosting too :no:
I am not to sure at what stage this was in Blacky's life so I'll let you explain that.
  • 1 month later...
Hey mate,
Not sure where i was up to. Last time we took it out the stocko gearbox was finally giving up the goast. Mike from MV Automatics is just about finished the new Power Glide, built to handle big power, transbraked with all the goodies... we should be hopefully have it in the car and running this weekend. For the time being ive been focusing most of my efforts on finishing off the new fully enclosed trailer for the car.
With the new box, were hoping for some sort of sub 10sec pass, just how far were not sure yet. At the moment were looking into getting the offset changed on the rear rims to sit further under the guards and allow a taller tyre as we have effectively run out of speed in the top end. this combined with a 3.9 auto diff gears and raising the rev limiter should hopefully give us enough MPH to stop hitting the rev limiter before the line.
We will also be putting the chute on this weekend as with the extra mph we will be getting very close if not passed the 140mph parachute req'd mark.
Plans for the new engine are slowly coming together, but money is a little tight as usual with most around chrissy time, but i have been doing a lot of research and plans include:
VH45DE:
Custom Rods
Custom Pistons
Nitrided & Balanced Crank
Decked and O ringed block
ACL head gaskets
ARP headstuds and rod bolts
Port and Polished heads oversized valves
N13 GTiR Valve Springs
Custom Manifold
and the blower?? dollars permitting a PSI blower (same as what the fuelers run but a little smaller)
but yeah nothing to new yet, hopefully ill be able to report back next week with some new killer times, either that or ill be crying that i have destroyed the rear cradle in the car which is about to get a whole heap of reinforcement this weekend aswell. will try take a few more piccies of everything as it comes along.
saaaa-weeet
sub 10 sec pass on a stock internals engine is a bloody good acheivment
has it still got the original driveline (ie driveshaft and diff) - i would have thought that it gave up (specially the diff) long b4 u made a 10 sec pass
ohh - would a roots type blower work? or would that require a lot of custom fabrication
or is the PSI blower a roots type blower?
Edited by usherly
The diff is a nismo 2 way, and seems to be coping fine with the power, Try 09's skyline years ago still ran a standard turbo diff to get to where it did. Drive shaft stilll has the standard uni's and center bearing just adapted at the front to fit the infinity box. When the new driveshaft goes in it will be a beefed up condierably and if possibly, length permitting a one peice unit.
The PSI blowers a basically a roots style blower but require almost no horsepower to turn them. You can spin the pulley on the front back and forth without breaking a sweat which you simply cannot do on a weiland/holley/littlefield style roots blower.
nice - so does this mean supercharger poking out of the bonnet?
sounds like a pretty decent setup and plans for the driveline
Thats exactly what it means :ninja:
Well gearbox left adelaide yesterday on express freight so i should see it late this arvo or tomorrow some time, then it will be rush down to hardy and spycer to get the tailshaft made and a full weekend at the workshop, fitting and making new bits and hopefully we'll be out next weds or sat or both if there on at the Test and Tunes scaring myself again, getting excited now!!
Gearbox finally arrived today, looks awesome, will dummy it up in the car tonight so i can measure the drive shaft and send that off to be made tomorrow, getting really excited now...
haha, yeah. Bloody thing doesnt fit... have to trim some little wing things off it on the side near the back of the pan. Parachute and gearbox fitting on sunday, them some skids.. and then drags on wedensday, farken crazy excited!!
2 speed glide, tube fram front end has gone on hold until at lest the end of this season, we dont want to make to many changes to the car at any one time so we can keep track of how each change effects, advatages, or disadvatages the car and then go from there.
Edited by NA_R33
  • 3 months later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
