Everything looks to be in the right spot. will have a close look when i put my new front pipe on.
Not what I mean as such. Everything might be in the right spots, but that doesn't mean the exhaust isn't pulling downward on the turbo. When I had my front/dump pipe fitted, the place doing it didn't bother welding on any supports around the cat to hold the middle of the exhaust system up. This meant that after the turbo, the first thing holding my exhaust off the ground was all the way back just in front of the rear axle. I don't even want to imagine the stress the turbo would have copped each and every time I hit a bump/went over a dip in the road.
Make sure there's something supporting the weight of the exhaust piping around the cat, and preferably NOT one of the rubbing mountings (as they still have give in them, defeating the point so close to the turbo. If you do have something, then I suppose that would more or less rule this theory out. Good luck though!
wow, never seen it before mate. it is nasty. I can't see how missuse could do that, and as you said you don't mistreat the car anyway. poor casting, or most likely come contaminates in the casting process. bugger!
be careful with the ezi-outs. many times I've seen a broken stud with a broken ezi-out in there..... and being really high tensile when the ezi-outs break they are fking hard to drill out and remove.
i've done that, made it impossible with the motor still in the car. luckily it snapped off far enough in to get a new stud infront of it and loctite it in.
If u do have some seized studs loctite make a freezing agent in an aresol can that I found helpful on exhaust studs. When u spray it into a snapped stud the stud shrinks because the spray has a contact temperature of minus 30 degress. Made seized studs great to get out. Shrink it. Wd40 it. Shrink it. Wd40 it and then start winding the ezyout. Obviously drill ur hole first though
Thanks for the tip. I start on it 2moro. Parts arrived from justjap today, they sent me the wrong front pipe
but no big deal, it's not essential.
Can you use this stuff on unbroken bolts? I might change 4 bolts which hold the turbo when I fit the new one onto the car. If I spray it with this shit and it shrinks the bolt, I imagine that with wd40 and two nuts it would be a piece of piss to take it. By the sounds of it, I could take it out by hand lol.
Does it cause any stress on the bolts and make them more prone to snapping though?
I am more than confident you got it wet when at opperating temp.
Drove thru a puddle, used the hose, etc etc. That would do it.
Poor casting from the factory is the only other aspect I would dare accuse, both are just shit luck. Loose bolts or poor support are both non events when it comes to a cast item.
Question: do you remember what you were doing right before it cracked and made the aweful noise?
No idea, i only noticed it when i started the car one morning and drove too
work.
May have started a long time ago when it started ticking, it wasn't that loud
and i just put it down to tappet noise.
