Hey guys. Once again the Mt Alma Mile hillclimb is upon us.
The event is held Sat 2nd and sun 3rd april @ Mt alma in the Inman Valley (between vicot harbour and Yankallila)
It's run over a 1.6km closed road and has multiple viewing points
This year out of 150 entries there is at least 15 skylines entered including keir wilson's R35 GTR - 9 R32's a couple of R33's and at least one R34
more details can be found here Mt Alma Mile Website
I was thinking about organising a group to cruise down on Sunday morning.
Meet up down south and head further south, if any one is keen, let me know and i'll Pm some details.
Hopefully see some of you there
Edited by Big Fella
https://www.sau.com.au/forums/topic/358073-mt-alma-mile-hillclimb/
  • Replies 83
well like i said, there should be a group of cars meeting @ Aldinga and then heading on down. if anyone wants to tag along they are more them welcome.:thumbsup:
Sweet...can I grab a lift if I get the time off?
yeah man, you'll jnust have to share the back seat with my 3yr old daughter. i'll prob be heading down on saturday by myself(wife's at work, kid's at grandmas) if you wanna head down on saturday instead???
Not really fussed, whenever really, I'll have to see if I can get the time off of work first.
In our team of four cars we have both our GTRs running - R32 GTR RH9 in full attack mode, and our R35 complete with new engine, bigger turbochargers (WR35TTR), and a new wheel tyre package. Should be interesting times for the Skyline fans :)
Great team that - should be at the pointy end of the field :whistling:
New Engine??? what happened???
We decided to put in a fresh engine with some good upgraded internal bits :)
That way the original sits on the shelf still running strong after 2.5 years of track work.
Lifing components is a very important part of racing cars, and much cheaper than letting them break!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
