  • 1 month later...
ive got in a huge arguement with a knowall who knows nothing on another forum regarding coolants, i work in a mechanical repair business specialising in exhausts and radiators, i change coolant every day, use whatver coolant you want, so long as it has anti corrosive properties that dont effect alloy as they pretty much all do anyway so you should be fine. Red or green, it doesnt matter, its just a dye. I cant remember the brand off the top of my head that i use at work but we buy it in big goon sacks in bulk anyway so i doubt it is retailed. We have both red and green and they both contain the same ingrediants, just different dyes. I run this in 2 of my cars and supercheap brand in the other and have never had an issue, neither have any of our customers.
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5828648
Any 1/2 decent 'green' coolant is fine IMO.
Since I like to get my radiator system checked (& cleaned if needed) every year, I just use the 'standard life' coolants & don't bother with the extra long life stuff (the 5 year stuff).
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5830889
r u joking?
Nope, i only ever used nissan coolant in my gtr. Pulled the motor down a few months ago and had f**k all corrsion in the coolant ports in the block, which is pretty strange for a motor that old.
Also we have problems with xtrails and d40's overheating at work. Mainly because they've used a non genuine coolant or cheap coolant which has started electrolysis in the aloy parts of the cooling system. Look into the radiator and you will see a fine dust like substance all through the coolant. This infact blocks the radiotars slightly and inturn they over heat. Put your multimeter in the coolant and check for stray current and you will always see a reading well over .3v's in these vehicles. These customers have voided all warrarnty in regards to the cooling system of their car because of this.
Not saying it would be the same in a vehicle with a cast iron block, but just gives you an idea of what can happen. Nissan have also released a tech bulletin to all the technicians about this which gives you an indication of how bad it may be.
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5831196
Also see that the coolant you use is for engines with cast-iron-block and aluminium heads.
Coolants for 100% aluminium engines are of a different consistency.
In general I would say that you have to stick to green or blue/greenish colours.
(Though this might not be a binding rule ...)
Basically there are 2 types of coolant:
Silicate based (green/blue)
Non silicate based (red/purple)
Here's the one I use:
http://www.commaoil.com/productsguide/view/6/353
https://www.sau.com.au/forums/topic/358403-radiator-fluids/#findComment-5838809
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
