So I've got
EXEMPT
LoneWolf (dope)
Wogan
Boss-Zilla
PewPew
Ten-Four
-Jimmy-
gazza750
turboedsloth
bubba
ohno1
J_32
R32 GTS4 4 Door
kingscorp
94GTR32
15 R32s and counting. Considering Perth has over 2 million people...you'd need a few more than 15 to be classed as common!
  • Replies 804
So I've got
EXEMPT
LoneWolf (dope)
Wogan
Boss-Zilla
PewPew
Ten-Four
-Jimmy-
gazza750
turboedsloth
bubba
ohno1
J_32
R32 GTS4 4 Door
kingscorp
94GTR32
I also have one.
Will post a pic later.
If someone organises a cruise...
So I've got
EXEMPT
LoneWolf (dope)
Wogan
Boss-Zilla
PewPew
Ten-Four
-Jimmy-
gazza750
turboedsloth
bubba
ohno1
J_32
R32 GTS4 4 Door
kingscorp
94GTR32
Sorry you will have to remove me and make it 14, mine was sold to another member about 2 months ago (once the house is sorted i may get another in about a year)
I also have one.
It's in the process of being organised bruv.
Thinking 3rd weekend in April (16th or 17th) atm...I'll get something more substantial put together and post it up soon!
My bunky.
Currently at 401rwhp, 11.68@119. Owned it for over 4 years now. Waiting on new gearbox to come from brisbane so I can drive it again, 4th gear went awol.
EXEMPT
LoneWolf (dope)
Wogan
PewPew
Ten-Four
-Jimmy-
gazza750
turboedsloth
bubba
ohno1
J_32
R32 GTS4 4 Door
kingscorp
94GTR32
heller44
Boss-Zilla i've removed ya ;) but we have 15 again as heller44 has just posted his 3 speed GTS4 up haha
^ thats pretty fresh, what size are the rims?
My bunky.
What turbo/s on it?
Edited by ohno1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
