  • Replies 804
arhh the old beast, wanna sell it?? Ha jk buit i do miss it, may have to take me for a ride in it. Done anything to it yet?
Im only good for the 15th or later (overseas before that :banana: ) but since i dont have a r32 does my vote count??
Yer im down for a may cruise
No faggotted show nshine bs though.. Cars are for driving
Ok just to clarify...MY CRUISE WILL NOT INVOLVE top bloke SHOW N SHINE SHIT...:cheers:
I'll get my dyno sheet up from last week tomorrow...
One more person says 8th and 8th it is!
R32 Collection Cruise 2011
Date: 8th May (Sunday)
Start time: 11:00am
Start location: Perth Esplanade carpark
Destination: Serpentine Dam via Gooseberry Hill
So guys PM me your mobiles so I can get an idea of numbers night before - we'll need at least 5 to make it a goer I'd say.
We got a bit of time before before the 8th so yeah talk shit in here or something in the meantime :nuke:
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
