  • Replies 804
yes you would.
When i put a gen GTR bar on my 32 sedan, i used the R reo (cause i was told i needed to, and the bar i bought came with it)
The only thing you'll notice when putting a genuine R bar on is that the sides buldge out a bit, due to the gtst being not as wide as the R.
Hope that helps. (someone correct me if i'm wrong.
depends who you ask! some say yes and some say no, try thegtr bar on the gts-t reo before you buy
I dunno about that lol, I see masses of R32's everyday gettin around my area. Very close to the same amount of 33's I see. They are all common but I still think 34's are the least common, especially coupes. Do see a fair few 34 sedans.
must be an area thing, naff all 32s in midland ,altho there is a nice n tidy 32 sedan up the road on great northern hwy
finally finished my repairs from the hail storm.... personally i think it's looking even better than before it got all dented.
thats f**king hawwt dude, rims suit it so well. always loved black 32s, but gunmetal has to suffice lol
Pulled the fans and intercooler/piping off yesterday. Degreased + highpressured the piping/cooler and the engine bay then cleaned the cooler core out with some thinners.
This afternoon the cooler/piping and fans will go back on and probably trim the front bar and bolt that up too.
Radiator was ordered yesterday :banana:
Clutch was inspected and deemed to need an overhaul kit.. ~$650 for the kit but not available until next month!! So looks like I'm going to grab a new Exedy button clutch instead.
Ordered my tensioners and idler this morning from Statewide Bearings, NSK part numbers, VERY reasonable prices!
The only unknown at the moment is injectors... anyone got some GTR injectors for about $100?:P
Fans back on, cooler on and plumbed up.
HID's wired but only one fitted because my drill went flat fkn (typing this while I wait for it to charge)... what a cnt of a job, the retainers in the wagon would have been perfect but the retainers in the 32 required some "modification".
Bonnet latch & support back on and operating well.
Need to pull the reo off and give it a bit of a grind tomorrow, the dodgy hacking from the previous owner fouls the cooler in one spot :(
Oh and a successful NIStune fitting today on a 34GTT, drive in drive out :D
Ok lets see if this drill has enough charge fkn
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
