  • Replies 804
Ahk, previous owner did the conversion on my car and I got pinged at the pits for the crossmember not bolting up to all 4 holes. It sounds pretty picky but I'd like to fix it anyway regardless of the defect. Just learning now about all the RB crossmembers (A, B and C) and S13 crossmembers as well (also A, B and C).
I have done some research and looks like most people say an SR20 manual crossmember (labeled 'C') fits.
I think when my conversion was done the auto crossmember was used and had flat bar welded to it so all 4 bolts were used
Pretty much what I did for the 25 box conversion but the other way. Used 5mm flatbar to extend the RB20 manual Xmember to pick up all 4 bolts holes (25 box mounts are further back)
Yeah fabricating something to fit is the best bet but I can't weld and don't have any time to take it anywhere haha. I think I'm going to get an S13 one this afternoon and see if it fits.
I haven't quite got my head around it all... I'm not sure if there's A, B and C mounts for EACH car (Skyline and Silvia) or just those 3 mounts that universally are used on both chassis.
Here's a pic (all are facing the same way), seems like I need the top mount.
Sorry to hijack the 32 thread with completely confusing and boring content.
I have the middle one but it sits too far forward. The bottom one is a custom one.
I will go out on a limb and say you have an R32 GTSt MANUAL Xmember.. I had to extend my holes with flatbar because the mounts on the 25t box are 50mm further back than the 20t box.
If it *looked* strong enough I don't see why not..
75PFC with 5mm flatbar extensions for the holes a gusset on each leg and decent welding (read: not dodgy looking) should be fine if you wanted to make one from scratch.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
