Yeah I've been hearing similar whispers from perhaps mutual sources, but that's been 12 months or so and still nothing :(
Be a nice option if it does come up for ~2k
Would sell a stupid amount of them just on a bang for buck basis.
  • Replies 45
Posted Images
Ah come on Simon you know that 370 is @ hubs (AMM's inflated Example 1 of 70rwkw inflated figures) and is closer 320rwkw like the 10 similar setups.
Anyways Noel - Why don't you just have an adaptor plate made up for the NEO? People have done it before (copies of the Blitz one).
You might wanna drop a PM to "Adz", owner of the wideboy 32 gts-t/stroker. I know he had at least one made... Perhaps there was a spare or a file you could get it redone from?
That'd work out in overall terms maybe 4-5k cheaper than going v-cam. Obviously v-cam is still better but it's a money for gain type of scenario and how far you going to go. There is always a (fine)line somewhere LOL... I did it too :P
400 was at ammrr's hub dyno with no temp correction. 370 with temp correction mode which brings it in lineball with rollers and is what trent from Status uses. get your facts right. it certaily distroys 320 rwkw set ups thats for sure
Throwing ideas out atm in regard to an engine I am planning. My original idea was to run a 26 head with HKS vcam but if the 25 head with the right springs etc can rev hard enough on hydro lifters it would be a more cost effective option.
WWhat sort of revs have you seen from a hydraulic lifter 25 head. I am thinking i need to get to around 9000 rpm to achieve the desired result.
Mate id suggest you get in contact with Paul at Red R Racing as he sent me a text the other day saying that they have their custom RB26 VCS head sorted. Looks like it may suit your needs perfectly.
Out of curiosity - what mods are required to make NEO head run safely at 9000 rpm? Springs? anything else?
Is there a possibility for clearence adjusting shims to jump off their positions at revs this high?
Edited by Legionnaire
That comparison is not fair as the Dynapack hub dyno is using STP correction which also inflates figures. Theres a few dynos on here with the fact they have STP correction turned on blanked out from the dynosheet posted. I dont care but when its convincing people buying turbos to change their decision its a bit wrong IMO.
Examples I have seen are 268rwkw -> 280rwkw, 308rwkw -> 325rwkw etc
Have a look @ all the graphs provided by that same mob. They are ALL in STP :merli: :merli:
he results are claimed incorrectly as rwkw and people are being wrongly mislead by thinking it is rwkw, end of story.
I totally agree RE: convincing people to buy things, or show results and then have it blanked out or claimed as something it's not. It's very wrong, but unfortunately people sometimes don't know better and when you do pull people up on it - they get all stroppy about it :wacko:
maxing out a z32 afm at 5 volts on full load full boost doesnt equate to 320 rwkw does it
As much as I hate to agree with Nazi Nismoid, he would be correct on this one. My car made 410rwkw with STP correction on and 360rwkw on the same tank of fuel on a dyno dynamics roller! But then again I was never it denial that this was going to happen haha :)
and my results are backed up with a fairly stout 132.5mph on the black dyno...
PS. On topic my stock RB25 head is happy revving to a limiter of 8100rpm
Edited by SimonR32
what isn't is making enough power yet? Haha
fineline, missing the context of your post... Are you trying to imply/suggest my motor isn't stock?
Nah mate, It was a sly dig at Nismoids love of all things stock. Speshly when it comes to making big powahhhh,
Ash got the gist of it. (insert tongue poke emoticon here)
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
