The idea for the video is to have a split screen.
Basically we need 2 stationary video camera's on tripods. Reason behind this is that the dyno screen for spectators is inside the shop and the dyno is outside and if we can get a split screen of the car on the roller plus the screen with the gragh, then it should give people a perspective as to what's going on.
This will only work if we can get someone that's willing to put the time in to merge the footage together.
I hope this makes sense.
I can merge the footage. I done picture in picture when we took Steve's rocky for a run:
if you're interested, my old man makes camera/video equipment on the side as a hobby thingy. like flying fox, boom, steady cam setups.
Really? I wish you told me years ago. I've been trying to make my own gear since 2009 but it was so difficult without a workshop like yours. You should see the basic steady cam setups i've made that hasn't lasted. Might have to have a word to your dad about it.
  • Replies 200
Prize update
Happy to announce a couple more sponsors that have generously donated some vouchers to the dyno day. A huge thanks to GSL RallySport and Import Monster for their generous vouchers.
[*]Naz from KMF will be awarding a $250 detail voucher for the most deserving participant car. http://www.kustommotorfinishes.com.au/
[*]Glen & Grant from ESP (Prize to be detailed). http://www.espracing.com.au/
[*]Mick & Trent. National Tyre Wholesalers Pty Ltd – Federal Tyres 6280 6109
[*]Thanks to MSCN Motorsport Mobile as they are sponsoring us for a $150 voucher to spend @ www.mscn.com.au
[*]Thanks to Dusty at MVP Motorsports for their $50 voucher to spend at www.mvpmotorsports.com
[*]Thanks to Aaron at Import Monster for their $100 voucher to spend at http://www.importmonster.com.au
[*]Thanks to Greg at GSL RallySport for voucher (tba) to www.gslrallysport.com
Yep, don't stress just yet. But if you know any local businesses that would like to sponsor a prize then by all means ask them.
Here's another Prize update, Shane from Gorilla Industries will be donating a $50 voucher. Thank you so much for this Shane it’s greatly appreciated. www.gorillaindustries.com.au
[*]Thanks to Shane at Gorilla Industries for their $50 voucher to www.gorillaindustries.com.au
Edited by RP071
That's a top vid !! Yep, that's what I was thinking. Would you be willing to give that a try and the dyno day? If you are what don't you have that you need to make this happen?
Ummm, I should have everything to make it happen..... I think. I'll try and put up a test video of what I think you have in mind, with some of my old footage.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
