i just saw this on the southern cross community whatever section in the ADs. i thought it would have booked out quick as. if there is spots on the day il run the bog stocker stagea, 206kw at the fly, then i can see half of that chewed up though AWD and the manual trans.
  • Replies 200
I put that in a number of weeks ago and I wasn't sure if it stuck on the website, but hey so it did. The only way to ensure your spot is to deposit your $50 into the account details listed on the front page. If you have to drop out for any reason I can organise a refund for you.
Cheers
Ross
Excuse my ignorance but Is it possible to drop an almost stock r34 GTT auto on the dyno ?
Stock GTR will still be in the paint shop :( and not yet run in either.
I can assure you that you will not have the lowest power figures on the day. There are a number of stock Celica's that will turn up, that's 1970's stock Celica's !!!
Looking unlikely that the GTR will be here (getting ready to burn the flamin mongrel) but for shits and giggles we'll bring the S3. Haha don't expect anything spectacular but I hope this will be a good "before" and maybe there'll be something to see next year :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
