  • Replies 743
ah looks good. Is the carbon fibre dash lighter then the factory one? I haven't been on the inside of a 35 so i have no idea what all the dash is made of. Does look pretty damn cool though.
yes there are weight savings in the carbon dash but the weight savings in terms of bang for your buck are no where near as great as replacing the bonnet/doors etc. we have already picked all the 'low lying fruit' in terms of weight savings
What you gonna do about glare off the carbon dash?
Looks porn tho :D
The glare will be insignificant. Due to the speeds at which this car will be travelling, light will actually be bending around the car, therefore eliminating any threat of glare off the carbon dash. :whistling:
I've got one of those old school terry toweling XXXX bar mats I was thinking of laying across the dash to keep it from cracking in th sun
Brilliant explanation :cheers:
Polarized lense glasses will filter the glare. Would be a shame to cover up such porn with XXXX mats!
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
