OK - Mum is too old for this shit now. Car has to go.
Conversion to Manual would make this thing a weapon, although the auto and high-stall combination makes for good drag stuff.
Only thing left to do is install a decent turbo/manifold/wastegate, which was next, but mum says no more!!! :flower:
This car isnt cheap. Genuine enquiries only.
Pictures in a couple of days.
1990 180SX Burgundy reg BP42WA - Lumpy’s Mum
Featured in Hot 4's some time ago with nowhere near these mods.
Engine
CA18DET
Bored & torque plate honed to 84mm with Arias Forged Pistons
Fully Balanced rotating assembley
Crank fully prepped – micropolished, deburred, balanced. Galleries grubbed
Tomei lightweight solid cam follower conversion
Tomei 260deg solid cams
Tomei Valve Springs
Tomei Cam sprockets
Tomei metal head gasket
Nissan Genuine Bearings
Nissan Genuine Water pump with custom made high volume impellor
Rebuilt Oil pump
Nissan Genuine other gaskets
Fully developed & ported head with heavy duty guides
Match ported manifolds
NICS removed
Polished everything
Candy powdercoated rocker covers
Custom lightweight/underdrive crank, alternator, water pump and power steering pullies
High flow thermo fan and shroud
Earles/Mocal oil cooler and remote filter
Custom aluminium radiator
GTR injectors
S14 T28 Turbo on ported original manifold
Autronic SMD management system with custom 4 channel coil control and auto-tune, stepping motor idle control, boost control, switchable antilag and automated rotational cooldown idle
Aftermarket coil packs
Turbosmart V port BOV in custom red anodise
60mm throttle body
600x300x75 intercooler with polished piping and silicone hose
Apex N1 exhaust, full polished stainless cat back
HKS 80mm cat convertor
Custom stainless front pipe
HKS split dump pipe
Full closed circuit draining catch can
Earles Braided line (with quality hose ends, not hose clamps!)
Rebuilt started motor
SR20 aluminium power steering pump
Bosch Motorsport fuel pump, in tank
Oddssey 800 battery
Serviced factory 4 speed auto
Dominator 4000rpm high stall convertor
Viscous LSD with 4.3 gearing
Massive trans cooler
Suspension
Whiteline sway bars
Whiteline poly bushes throughout
JIC radius rods
Apex Adjustable Shocks with Whiteline Springs
Cusco front Camber plates
Hicas removed
Carbon fibre front and rear strut braces
Brakes
R32 GTR 4 piston front calipers with 296x30 rotors
R32 GTR 2 piston rear calipers with 300x18 rotors
R32 GTR master cylinder (compatible with factory abs)
R32 GTR Internal drum handbrake
Braided rear brake lines
Nissan genuine pads
Factory ABS
Wheels/Tyres
DTM Fin 17x7 wheels
Uniroyal RTT-02 Tyres 215/45 front
Uniroyal RTT-02 Tyres 235/45 rear
Interior
S14 front seats
Factory head up display (still works!)
S15 leather shifter
Kenwood CD tuner
Rockford Fosgate front speakers, in stock location
Pioneer rear speakers, in stock location
Tint
Alarm with locking & battery back-up siren
Late S13 SR digital climate controller
Greddy Electronic Boost, Oil Temp, Water Temp & Exhaust Temp Gauges
Greddy single gauge A pillar pod
Hyperdrive 3 gauge on dash pod
Body
Carbon fibre bonnet (original bonnet included)
Genuine Wise Sports front bumper, modified and ducted
Genuine Nismo side skirts
Genuine Nissan rear mud flaps
Nissan Type-X rear wing (late model 180SX)
Clear front and side indicators
Factory Sunroof
Uprated headlight globes
Price $25,000. Will discuss offers and options.
https://www.sau.com.au/forums/topic/36025-fs-lumpys-mums-180sx/
Yeah, the car is here every Saturday. With the exception of a rego sticker, a small LUMPYROM sticker on each front gaurd, and a QEII hospital parking permit sticker on the window, there are no stickers.
This Sat it will be here for sure, as it's having photo's taken.
    • Private profiles, adult chat, and local dating in one place https://privateladyescorts.com discreet sex dating
