Just looking at plug and play ecus for my r33 gtr..
And came across this one (link to follow) my gtr just has 3,3/4 inch ss exhaust a k&n panel filter and thats it well all i know of anyway...
Here is link is it a good idea??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260763289031
https://www.sau.com.au/forums/topic/360255-thoughts-on-this-ecu/
See thats what i was thinking too (Ie i am worried about our weaker fuels) just wanted to see what others thought of it before i took the plunge....
take the plunge you will love it!!!
just beware the modding bug, im about to swap turbos hahaha had the car a yr :P
I wouldn't risk installing anything like this in Aus, cos of the huge differences in fuels, climates etc between us and Japan. As stated above, best to get yourself a PowerFC or something similar and get the ECU tuned specifically for your engine, better investment to spend that extra bit of cash now rather than potentially destroy an engine.
So you guys reckon i should just save up the extra say $800 ish and get the power fc to be safe??.....
Dont plan on going mental with mds (I cant afford too!!) i just figure it runs rich anyway from the factory so why not make the most of the fuel being burnt and get a better ecu...
Just to note i did a ecu test (Ie the plug under the dashed pinned together etc and only got fault code 55 (which means no faults) i thougth i had a dodgy 02 sensor and thats why it stunk so much of fuel....
The standard ECU tends to go a bit silly/overboard with fuelling when the boost is increased that is why you would be getting a rich mix, best just to play it safe mate - spend the extra to get it done right the first time.
You will not only get more power but way better fuel economy as well - win, win.
hi
the ECU you are looking at on ebay is un-tunable, that is, you cannot edit the tune, update it, change it etc
it is a once only tune and you are stuck with whatever settings are on there
ie its junk and you cant use it
options such as the powerfc, vipec, motec, autronic, nistune etc let you tune the car as you want
so you can buy it, put it in your car, have your tuner "tune" it and set it up to suit your car
remaps (which is what is in the ebay ad) are basically a flash edit of the standard ECU
but the problem is no one can update the flash tune, so its basically read-only
only select few could edit that map, and it wouldn't be worth it
for a GTR, the powerfc is prefect and well worth every $
and you can resell them for the same price you basically but it for
for info on the powerfc check my signature for the PowerFC FAQ
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
