+3 for copy of original, do you still need the whole surround Shane or are you sorted
Yes, we need the whole surrounds so that we can understand how they attach and manufacture accordingly. If anyone does have them, please let me know and I will look after you with a free set of lenses. Be aware that we would need the surrounds for the duration of the project, so this must either be a spare set or from a car that is not on the road at the moment.
wow you really smashed it up... I was able to remove two with no damage, so I think your being too rough pretty much
How'd you get yours apart? I gather a bit of heat to loosen everything up?
Hopefully it will work out affordable enough for psi to make the whole unit so it's a direct swap, would be nice and easy that way
yeap a bit of extended low temp oven work, make sure its a low temp though, you dont want to soften the lense itself just enough to make the glue workable...
Im still keen to get some time to try cutting the fog light lense down to fit, but whatever works really....
are you able to shave the side indicators legally though, I thought you need a side indicator but some cars can get away with it because their front indicators are usually where our parkers are and since can be seen from the side???
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
