hey all ! i just want to put some spacers on my car to clear my brakes!
just wondering how long are the wheel studs on the r32 gts-t? and how thick of the spacer should i buy ? i was thinking of getting spacers from Just Jap prob 20mm to 25mm.
what you guys think? i need some advice!
thank you all!
https://www.sau.com.au/forums/topic/360833-wanting-to-put-spacers-on-my-car/
  • 2 months later...
hey guys, sorry to hijack but I didnt want to start a new topic.
Basically I want to get 25mm spacers for my GTT. A lot of people are recommending the H&R ones? I'm wondering why this is? Anyway, I can get the H&R ones sent from the US (http://www.optionimports.com/itemdesc.asp?ic=HR5065662) for $220 or buy the Just Jap ones (http://www.justjap.com/store/product.php?productid=17024&cat=269&page=1) locally for $140. Any thoughts or comments?
The problem with the hub centric ones is if you go any smaller then around 25mm you have to cut a little of your old studs, unless you wheels have cut outs or extra holes for you old studs to stick through.
s
Either way spacers are dodgy and illegal and cause to many probs, I had nothing but dramas on my 31 even with hub centric spacers.
Its essential to have the correct hub size or use adapter rings. In NZ the max thickness allowed is now 20mm - you may want to check if there are any state rules about spacers. I can't imagine why they should cost over $200 unless they are made of titanium.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
