  • Replies 85
the black nismo alloy knob rocks... and the heat doesnt bother me either... but one with a red glowing H diagram would be neat...
Yeah, would be awesome if they can do it in aluminium with H pattern :D:D:D
still keen :thumbsup:
Please put one for me as well. Let me know when you buying
To easy guys. I'll PM you when I open the group buy. Might do it tonight or tomorrow.
i'm interested.. but how will it fit againt the skyline gear stick? this picture looks like the gear stick is lower down? will the boot marry up to the skyline?
dont they have to do more than just make it 10mm to fit the skyline?
ie. shape of the base surround, height of the stick, etc?
Other than the diameter the only factor is the length of the internal thread in these new gear knobs. If there is plenty of thread it will bottom out on the stick and won't be a problem. If the length is short, it may not go all the way down and sit a little bit higher. This really depends on how tall the gear stick is that you had on there before.
In regards to the gear boot. I suppose it depends how much play there is in the boot. Mine is custom made and is a bit baggy so should be allright in that respect. In regards to the base of the boot once again varies from boot to boot in how it is stitched.
However I want to replace mine with suede and I have found a manufacturer in the UK that does good ones for good prices. So we can always get custom made ones to our specifications.
Please let me know if I am over looking something.
Phil, not sure if you have mentioned this or not, but do they only make it in leather?
I want aluminium xD
The ones I posted on the first page are the ones they make. All have leather.
Basically the options are as follows (I will go into more detail in the actual group buy):
-All leather
-Leather with a ring of chrome
-Leather with a ring of aluminium
-Leather and chrome mix
-Leather and aluminium mix
Ah yes handbrake boots! Forgot about them. Definetely keen on that aswell since mine is the factory one and looks a bit old now.
Wouldn't mind actually doing something about the handbrake itself. Havn't really seen any one doing anything on a Skyline though.
my little bro has the nismo alloy one in a black 32. gets real hot in summer, but is easily fixed by removing it from the car and running it under cold water for a minute or 2...or until it stops steaming :happy:...seriously tho. it gets real hot, even under a sock
I would be keen, any idea on how they will sit ? Ive got a small "ball" shaped one and I love it, I bought another one of eBay and it was a stick type one and it sat up way to high, to the point were I was literally punching my stereo when changing to 3rd.
Just do what I done when I accidentily bought a m12 nismo knob, get a 10mm bolt, put it at the end of a screw so you have room to work with it, then using a bench grinder grind the edges till it's perfectly round and fits the m12 hole in the gear knob, then just epoxy it into the knob, whole process should take about 30 mins :)
Also just so you know why I havn't posted the group buy up yet.
I'm just trying to confirm with them whether the gear knobs actually have a thread inside them or whether they are just a hollow shaft. Because I believe a lot of European cars don't have a thread on the end of the shifter, they are just a shaft.
EDIT: Here is an install I found. See how there is no thread.
http://www.seat-leon.de/vboard/showthread.php?t=70056
The group buy will be for the gear knob only from this supplier.
There is another guy in the UK that does really good quality gear boots which we could also do a group buy for. However that isn't in the plans at the moment.
I know when my mate changed his gear knob on his E46, it wasn't threaded inside the knob. Just had to pop off the old one and slide the new one on.
So they do or don't have a thread in them?
That's what I'm trying to find out.
I emailed them so waiting for a response.
If not, as Craig said, we could just hand tap them since i'm assuming the inside would be aluminium so should be soft enough to tap.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
