Got a Marder II at the moment and having heaps of fun with it. Any recomendations for good German tanks?
The Marder is one of the best tanks in the game (for it's tier). Other good German tanks are the PzIV, VK3601, Tiger P, Tiger II, VK4502A, Ferdinand, all tier 9s, Maus. German arty isn't bad either.
  • Replies 376
Posted Images
are any of you guys experiencing the crash to desktop problem?
it happens to me after every single match
I've uninstalled the game, re-installed with new 7.4 setup, it does it with mods, without mods, tried lowering graphics settings...
nothing works
nothing works
I get it occasionally with the exit or load game CTD.
If anyone wants to run platoons or company battles and wants to get into Clan Wars in the future but doesn't quite have CW ready tanks or just want to get some experience in organised team play before jumping into CW. The Steel Parachutes - Pacific is now recruiting.
You'll have access to the TSP forums and teamspeak and will be playing with regular TSP members. If you want to get to know some of the TSP members first and have a few games you are most welcome to connect to TS, join the WoT channel and say hi.
Shoot me a PM here or on the WoT forums (same name) if you want any further info :cheers:
Are you guys still playing on the NA server or did you move to the new SEA server?
Heard the new SEA server is full of nothing but noobs... I think I might switch & enjoy getting game after game of easy victories! :yes:
Some people get no different ping, the tranfers are going through in one block so people have been waiting a long time. The server population is so low there are a lot of lop sided battles in the upper tiers and there are few english speaking players.
A server full of noobs? How is that better? At least you can create an account on SEA, intstall the game in a different folder and play it seperately first.
Has anyone tested out the new T10 meds on the 7.5 test servers?
From what I've read/heard, they get 260mm+ pen guns with your usual med spec rof.
This to me is like another blow to tanks like the E100 (already one of the worst T10 heavies imo) are pretty much completely useless now.
Hopefully my IS-7 doesn't get effected too much.
Edited by Mayuri Krab
E-100 and Maus are being buffed.
Hopefully that 155 gun on the E100 actually get a pen buff as it is kinda lame atm that I can bounce a direct shot in the face at short range just by moving back & forward in my IS7.
  • 4 weeks later...
Finally had enough & bined the IS7...
With the new TDs & Meds running around, dam shit feels like a crap old IS-8 with no armor.
Too bad it was my favourite heavy of all time before the patch... & went to the top of the most hated list right after.
Will bin the IS 4 soon too, that thing has always felt crap since the move to T10.
  • 3 weeks later...
  • 3 weeks later...
Well my account is getting transfered to SEA as I type.
I played a couple of games before hand & was getting <100ms (60 - 90ms) in general, that kind of ping is good enough to play even FPS for me =D
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
