anyone got a install guide for R32 GTR dump pipes? i took front pipes off and now trying to get dump pipes off is shitfight. looking at just getting ratchet spanner hoping that might make it easier. car is now in pieces so any quick help appricated.
https://www.sau.com.au/forums/topic/361613-r32-gtr-dump-pipe-install/
depends...are you upgrading the turbos?
i started mid day saterday, had the turbos off by 7ish that night, then turbos on sunday morning and finished abit after lunch
but i had all the tools, all new gaskets etc etc so i didnt waste time to go source parts, plus i was lucky and my oil/oil lines didnt crack like alot do due to age
Put it this way, if you arent sure what changing the turbos would involve off the top of your head, you surely arent ready to handle such a task.
I have done many conversions and do not like the idea of doing GTR turbos with the motor in the bay.
i've done this without taking the turbos off, did it over 2 days and a few trips to the shop for a couple of tools I didn't have. You'll need a 13mm crescent wrench for some of the turbo to dump bolts. Getting the dump off the front turbo is possible without removing the rear turbo, but it may be made easier if you loosen the rear turbo to manifold bolts so you can move it a little. Here's some pics. It doesn't mean it's easier to do with turbos on though, just possble......post-48345-0-60735200-1303342764_thumb.jpgpost-48345-0-10348300-1303342732_thumb.jpgpost-48345-0-56935300-1303342695_thumb.jpgpost-48345-0-10152600-1303342657_thumb.jpgpost-48345-0-65060200-1303342605_thumb.jpg
I wrote this a while ago, might be relevant to your situation:
http://autospeed.com/cms/title_GTR-Revisited/A_111537/article.html
As said above, it's probably easier to remove the turbos. If for no other reason, than with the turbos out, you can be sure you get a nice even clamp with the bolts onto the turbo/dump gasket.
Removing turbos is not actually that hard if you carefully read the factory instruction manual and follow the sequence of removing stuff.
Also, remove the power steering pump - it seems like pointeless work but trust me it makes the job that much easier.
Also invest in a set of ratcheting spanners.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
