Wow amazing! About bloody time some one updated the "spark plug". Was actually discussing this with my mate a few months back talking about how there really havn't been any proper advancements in spark plugs for decades other than using precious metals as electrodes.
i would be concerned about the battery's ability to handle the laser ignition...
Batteries provide a huge amount of capacitance, so I cant see any obvious problem. What am i missing?
Pfft - diesels have been running without spark plugs for a century. Nothing new here.
how the hell does that compare? diesels have a compression ratio of something like 20:1 to ignite the fuel. try using that kind of compression in a petrol engine.
i have no idea about batteries, that's my problem, i'm looking forward to see what can be done about these laser ignition systems, and would they be relevant to our aging RB engines?
That's exactly what I was wondering. Surely the roll-out of this technology would require serious modification to existing vehicles? Ecu, coilpacks, for a start would probably need a change.
i would reckon its not just supplying a current, but also the timing and such, not sure how electrical signals work, but maybe, there can be a "translator" sort of thing that changes the signal for the sparkplugs to something relevant to the lasers?
Hmmmm sounds cheap lol. It'd need a retune to take full effect of the new technology though.
Lol I guess if they lasted a lifetime though they may pay for themselves (it'll be a while before the new technology becomes that reliable)
i wonder how they'd get around the carbon build up on the lazer lens. unless it closed somehow.
Maybe like a spark plug does now - the laser could burn off any carbon.
Next step to upgrade the tech on an RB would be direct injection since that's a mature technology already. The laser stuff is a while away if it ever gets into production.
I reckon internal combustion has got a fair bit of life left in it. Either ethanol or gas (Australia has shedloads of gas. There's just been a $90 billion 20 year deal signed with China).
In regards to the battery issue...BMW and M-Benz have been pushing for 48Volt sytems for a few years now.
They say they have gone as far as they can using 12 volt
these cars have elec brakes/steering/throttle/suspention & 11ty diffent computers etc
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
