  • Replies 139
yer but no one inspects every single batch on a regular basis. bp98 is considered the best here but even so i've had one batch that needed 7 degrees of timing taken out across the board under load to stop it pinging badly, unless every batch before that was 105+ theres no way that tank was 98. not a once off either, its happened a few times, just not always that bad.
Marko, I hate to be picky, but I will... you also did the same thing in your opening post. :D. Must be an inherent anomaly with the Blackberry. I'd get it checked. :nyaanyaa:
PS, withheld would be a better word :D
PSS, I am keen to try E85 when I finally get my car finished.
u must be a journalist haha, u ballbreaker u :)
The only logic in not running E85 Marko is the range. Engine safety from the point of view of detonation/knock is better on E70/85, and the minor variance in AFR is minor. You may well be more likely to detonate your engine on a bad batch of 98. Your tuner is being left behind....
Does the legal requirement for 98 dictate at the bowser though? It'd be near impossible to guarantee that after all the contamination between refinery and the pump. All it would take is that fuel sitting for long enough in the servo tanks to drop in octane.
Yeah at the bowser, companies cannot market it as 98 if it's not.
If they get found out there are ramifications. But realistically it's not that well policed... Can't go around checking up on the people that make the Gov't loads of money now can we?
The joy of typing on blackberry with a mini screen, I left out "not to be"
Stevo - that's the other reason e85 is not for me as I also like to take long drives and will become stranded on e85
You can have 2 fuel maps with the Vipec, use one of the digital inputs with a switch to change between an e85 and pump fuel tune.
i was unaware of that - i still have a lot to learn about the vipec capabilities (still thinking of my dinosaur pfc)
So, changed your mind yet, Marko?
Atm I'm smashed, drinking all day and had a 15kg pig on the spit so my mind is clear...I'll stick with 98 pump and my 700cc injectors and leave it with my tuner (crd). So how my pierburg fuel pump runs as they support 500awkw without a problem
I was getting prices of $500 just for the ethanol content sensor a while back, have the prices come down?
Or you could save yourself the hassle and buy the V500 Ecu instead. It's pretty much the same price as the vipec/haltech/Autronic etc but does so much more. That's the beauty of running multi-controllers.
Then you don't need the E85 sensor, you just need a wideband o2 which are approx $125-$150
Could you tell more about this ecu and how it works with the wideband please?
This was already explained by Hyped6 about a page back. You use lambda as a reference input into the ecu and have it add fuel if it sees leaner mixtures above a certain rpm/boost level etc.
You can put tables over tables over tables to achieve virtually any result you can think of
what if the wideband packs it in?
What if the E85 sensor packs it in?
What if a massive comet comes from outer space and crashes into earth?
As long as you change the sensor out every 100,000k or 50k if you are paranoid, then you will be fine. You could also argue about the e85 sensor and changing it out, but at $500 a pop?, hmm.
What sort of switch can you use for this?
I'm running an Emanage Ultimate setup with E85 and LPG tunes. Right now I need to flick the dip switches each time I switch fuel.
I'd love to run a switch to the driver's side so I can switch tune on the fly. The Emanage has two "Options" input...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
