  • Replies 163
*whinges* when's the GTR coming home to daddy?
I gave Adrenalin a call yesterday afternoon and it "should" be ready for me to pickup this Friday or sometime the week after that depending how long it takes for the plate to be sent out, all the work on the car has been completed and approved just waiting on the plate now.
Its getting a little exciting!
Also to whomever is organising the next one, we really should be using the EVENTS part of the QLD forum to be organising these meets, been suggested to me by a certain someone :)
If our leader Slip is allowed to have an Event sticked at the top of this part of the QLD forum then surely we're allowed too?
I stick the Skidpan ones there for a few good reasons. I am making a thousand dollar commitment when I book a skidpan, so exposure and turnout are very important.
These thrusday night cruises have so much response they will stay up the top in the events forum anyway. Skidpan threads can have quiet times but need to stay up there.
If I have some time I will try and come. Drove my car for the first time in 3 weeks the other night to get some food.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
