  • Replies 163
Sort of used to live around that area, know the showgrounds which is basically opposite where we are going, I think.... pretty easy to get there though:
If you guys want me to take pic down just yell out!
Uhm... I wouldn't go to that meeting spot if I were you. There's been trouble there in the past with hoons and it's a pretty well known meeting spot.
Maybe choose somewhere different?
you refering to the final destination or meeting spot for both brisbane crew and GC crew to meet up?
Why all the Pm's if the meeting point and even a map are gonna be whacked up like that?
just following the tradition. if you guys want, i can post it up for ALL to see.
i believe the aim of thursday nite cruises was to avoid hassles from the police but i do think they have caught onto the thursday cruisers now
Yes I wondered about that, as a speed camera was placed conveniently at the entrance of BP Yatala last week :D
:werd: on that trap at yatala... very convienient... I've never seen a camera that far OFF the road... EVER
Is the meeting place the same as the latest PM genisis?
SKa, il meet at yatala, let me know what time...
Im up for a good night, works been a bitch, im over it all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Any jobs at umart chris??? lmao.
Check this :D under the "Be afraid !!! be very afraid" post ... congratulations for both of you, but looks like Strutto needs some help with his spelling......
http://www.skylinesaustralia.com/forums/sh...88&page=2&pp=25
go down to the last thread. Hey, i might join as a moderator to check on the moderators spelling and grammar......hihihihi...... :P
Seriously I have several freinds who are police and they all deny any knowledge of anyone viewing forums (As they probably would do even if they knew or not) and then going and raping meets, but also they are fairly low down in the scheme of things, but having conversations with them tend me to think that you guys are just paranoid.
BUT there are a lot of people here with a hellofa lot more experence with these things so I agree it is better to be safe than sorry, just never heard of anything like that happening, only rumours and heresay so I dont want to find out through experiencing it happening.
Sorry bout the pic, thought it would be fine to post the starting meeting place, my bad anyway I'll just shutup now and follow the leader :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
