So enyone going to join me at Wakefield on the 28th May for the SAU V Rotary 2nd track day?
http://www.skylinesaustralia.com/forums/topic/361770-s-a-u-n-s-w-wakefield-trackday-number-2-for-2011/page__gopid__5775117
Currently I'm able to claim the slowest and fastest times for the ACT. I know its a bit but it would be good if someone else could afford $400 to do a track day in the "sports" car we all own.
https://www.sau.com.au/forums/topic/361829-wakefield-28-may/
  • Replies 86
Doesn't bother me there'll be plenty more track days. Mine was on the road most of last year and I've been to the drags 4 or 5 times in the last 6 months and that's been fun and crazily addictive!
Should add, the main reason of the offroading was actually gearbox repairs since I busted my second gearbox at WSID in Feb :)
Yes rubber and pads will be needed. Pre and/or post.
Just make sure your car and you are ready. Some people take their car to the track unprepared and come home in the front of a flat bed tow truck. Talk with someone who's been a few times and listen. IMHO - Cooling, oil flow, suspension and braking will make your experience a happy one.
:thumbsup:
Edited by Sinista32
Yeah new front pads before you go...rubber well that depends on how hard you go...my 33 on street rubber lasted a few track days but was taking it (kinda) easy and cause im awesome had no spins/offs :P, but passenger front tyre gets hammered at wakefield
GTR will be even worse for front tyre wear.
Also Fresh oil and 500ml overfill to prevent oil starvation
No loose objects (take out everything that might hurt if you crash and that includes subs/amps etc)
A wheel alignment before you go (nothing worse than the car darting to one side under brakes at near 200km/h)
And most importantly pay attention to what is going on around you Check your mirrors lots and let the faster guys through when you can
and watch for any yellow/red/chequred flags
and
RELAX AND HAVE FUN!!!
Ive heard after you've pretty much earned yourself a new set of tires and brake pads.. any info on that ?
It's not as bad as some make it out.
Tyres: I have Federal 595 RS-R, they have lasted 3 track days and will last another one. That have a 160 wear rating (fairly low) so other tyres should last longer. (depends on how you drive as well) As long as you have 50% tread you should be fine.
Brakes: I got 1 1/2 track days out of my original worn pads, About the same for the disks. I upgraded the pads to EBC yellow and RDA rotors from the group buy later and have not had an issue with 3 track days, they still have plenty left in them. Again as long as you have 50% life in pads you should be fine. I note I am looking and a big brake kit now, but the brakes suffice for now.
Oil: I always put new oil in and put and extra 500-1000ml in after it is full as a safety margin. Also replace the oil after a track day.
Oil temp: Do you have an oil cooler? If not you I stongly recommend Castrol 10-60, it will keep your oil temp lower all day and keep that important protection at the high levels of heat a full track day will cause. I have a spare bottle if you need as I should get my oil cooler before the track day.
Fire entinguisher: Get a supercheap one, securley install somewhere you can easily reach it. Mine is bolted to the car, if that million of 1 chance you get into a serious accident you want to know where it is. (also CAMS requirement)
Metal valve caps: Just spend $5 at supercheap and get them.
Wheel alignment: Unless your car has not had one for ages or shows signed of needing one, save your money. The best alignment for the track are terrible for the road, lots of camber. If you can take your car up on a trailer, then get a track based alignment and then set it back to a normal alignment when you come back.
Other issues I've come accross
Turbo's: If you still have the original turbo's, they are a time bomb 15 years old and not made of metal. Get them replaced. I learned the hard way.
Intercooler piping: Replace with a hard piping kit, 15 yo soft piping does fail.
Variable torque controllers: Great things to help stop the rear end swinging out
Trailer: Great for if your day ends suddenly, also easier end of the day drive back and you can make some great mates with people who you lend it to if need be. Luckily I've never been in this situation and I will be driving up.
RSR's are track tyres (kinda) so handle the temps better, normal road tyres fall to bits and make you feel like you are driving on ice when they get to hot.
I never said go and buy Ikeya Formula Suspension arms and spend 2k on an alignment, I said get one to prevent things being difficult under brakes/mid corner etc You WILL find issues with your suspension on the track that you would never notice on the street
Also no need to go buy new turbos for 1 track day.
Just turn the boost down to standard and stay off the limiter
and your right foot, stops the rear end getting loose :P (bloody Cheater cars lol)
Also no need to go buy new turbos for 1 track day. Just turn the boost down to standard and stay off the limiter
I can only say that in my experiance with the exact same car, I've had the 595 SS and they didn't fall to bits. Actually no tyre except the very expensive type has ever gone off on a track day when the heat gets to them from the people I've gone up with. On the other hand I have heard plenty of people complain about their slower then expected lap times and blame the tyres. Not sure this was the tyres fault :P. Put it another way, ever watch "days of thunder"? When the mechanic tells tom cruise how to drive, he gets better times and doesn't tear up the tyres. Drive a car smooth and far less damage is caused to the tyres, any type of tyre. Saying that, you will use a lot of the tyre during the day however you drive.
Again I have not experianced any issued with my standard alignment going to the track. I do not think this is worth the money unless you know or think there may be a problem. That's my opinion based solely on my experianced with this car, track days, and common sense. Yes you will notice effects more at higher speeds, but they will still be there at slower speeds. You would be better spending the money getting a place like ESP to do a full check over of the car to ensure it is right for a track day.
I probably would not buy new turbo's for a track day. But I ended up with a 10K bill for repairs because that is exactly what happened to ME. Boost on standard and doing a warm up lap. (OK I got a few upgrades at the same time) I've heard many people doing track days on standard turbo's fine. I've also heard of plenty of ORIGINAL turbo's failing after 10-15 years of use.
I get into trouble with Dereck from 5th gear about my right foot all the time. :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
