Hi Guys and Gals,
For the upcoming Drag Combat event (April 10th) I'm planning on having some more t-shirts made for the event, similar to the ones we had for PAS. This time the t-shirts will be black, and will have the SAUWA logo, and Drag Combat logo's on them.
The cost will be approximately $20 again.
If your interested then let me know sizes, and send me some money, either directly of via Netbank. Be quick as we don't have long to sort this out. The t-shirts are very good, and I wear my PAS one all the time.
For the sizes, I wear a Medium, and people like Cam wear XL, so judge your sizes accordingly:D
Cheers
Paul
Kyles, XXS Paid
IMACUL8, XXL Paid
RB20LagWagon, S
Nizmo, S Paid
Sileighty, XL Paid
Memphis, L
Mikz, XL
Caminperth, XL Paid
Sneeza, M Paid
Shuto_boy, M Paid
13_Devil, S Paid
33Spec2, M Paid
PVA_Glue, M
Judged, XL Paid
Got Boost, XL, L Paid
GTS500, XXL
Drifta, L Paid
MrGTST, XL Paid
dan_the_man, L Paid
Neo, XL, XL Paid
Gradenko, XL Paid
Boostzor, XL
Micko, L Paid
Sub, L Paid
Wilz, L Paid
Skyzerr33, XL Paid
SeriesIIGTST, L Paid
Erik_tufa, L Paid
boost, L Paid
Vassil Paid
https://www.sau.com.au/forums/topic/36243-t-shirts-sauwa-drag-combat/
  • Replies 49
The easiset way to pay is via Netbank:
Bank:Commonwealth
Account Name: Paul R Cornes
BSB: 06 6163
Accnt No: 1000 6120
PS. Remember to include your forum name in the description.
paul, can i come around and pick it up from sst , as i cant net bank
-paul how big are u? i think small should be good size 4 me
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
