I changed to set yellow jackets and my car is miss firing badly under boost. No matter what gear it misses. The car was perfect with stock coils. Easy driving does not cause any miss only hard driving. I noticed too the plugs look gapped down. I've got a brand new set of bcp7res11 to go in. should that cure the problem?
Did you change the plugs at the same time as the coils? If you put plugs in with a wider gap, that would explain it. Otherwise, check all the electrical connections are clean/tight.
FWIW the more boost you run, the harder it is for the spark to jump the gap. The smaller the gap the easier it is.
Why did you change if the stock ones worked?
Stock ecu, 9psi boost exhaust fmic. Changed as I'm
upgrading turbo ecu injectors etc. I'm using the same old
plugs didn't change em. Pretty sure everything is tight. Could the shorter gap with these coils cause misfire? The only thing I changed is the coils and then the missing started.
Not sure what you mean by that question - the gap is the same since you didnt change the plugs right?
Not a good sign, you may have a bad coil. Check the resistance of the primary winding on all six - it should be the same. The spec for the stockers is 0.6 to 0.9 ohms and the yellows should be very close to that, middle and left pin when looking at coil plug. The primary winding check can only confirm if its bad, not that its good.
EDIT: Sorry that spec is for external ignitor coils only. Since you're Series 2 you wont have an external ignitor and the spec/pins will be different. I'm guessing it will have 4 pins instead of 3?
What is the point of upgrading them just to have problems? this is pretty bull. There are 3 pins ib g and a plus symbol.
what I meant by the gaps is the current old spark plugs are smaller gapped. the new plugs are 1.1. Would the new plugs and the bigger gap eliminate this? only other choice is change coil by coil...
My old plugs are heat range 7 they were fine. My new plugs are identical to the old ones apart from the gap. 9psi. Its 100% related to coil/spark plug configuration. My old coils spark combination NEVER misfired. Only after installation of these coils did the car start misfiring.
why did you change the coilpacks if you didnt have an issue?
does it feel like only 1 cylinder is misfiring or a few?
put the stock coilpacks in 1 at a time till you find the dud,
also don't rule out spark plugs just yet, check each one very closely for hairline cracks etc, also check the electrode condition/colour and see if there is 1 that is different.
Going to be running much more boost with the new turbo so(18psi) this is generally the first step as the old ones are going to be pretty tired when it comes to the increased load. I have no idea but it kind of comes in bursts of misfiring, not just one splutter but like splut splut splut splut. It feels like this video. Ive pulled them all out now, they were a factory second unit which I bought from performance wise and paul is more than happy to take them back and replace with a new set and test out the old ones. Just to ensure it is the coil packs, Ill be going out now for a drive with the old ones back in to see if it still does it. I doubt it will because I never had a single misfire whilst driving on my old coils. I checked all spark plugs except cylinder 4(under the crossover pipe, I'm lazy lol). They all looked near perfect for spark plugs of their age. I have started a thread a while ago asking people to check out the condition of my plugs. Very clean and healthy looking. They looked the same across the board(apart from 4, couldn't get to it).
Mine did exact same thing turned put to be dodgy boost t was over boosting.. Try turning boost down, is it happening at night / cooler weather?
I run a Greddy Profec B spec 2 boost controller. Haven't fiddled with the settings since its been fitted to the car. Happens any time. Happened last night coming back from work. Happened the other day driving to just jap(40 min drive so warm engine bay etc). Lets see what happens on the drive now. Maybe I did crack a spark plug when fitting it back in but I won't be able to cross anything out until I drive it now.
1:25 seconds sometimes it gets as bad as that and sometimes there is no break between the misses, it just keeps missing all the way.
Took it for a drive, let it warm up properly. First gear all the way to 6500rpm, second gear to 6000rpm 3rd gear to 3000rpm, not a single miss. Using the same spark plugs, same boost, stock coils. I can go out now and test each coil, just by swapping one at a time with first and it will miss with the faulty one but there is no point. It is definitely the coils. Fit them in, they miss. Remove them, miss is gone.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
