still just a maybe at the moment Erin , will find out in afew days when the line will be ready ! Any more info about the SAU QLD club , will it be starting on that day as well ?
  • Replies 232
I need to buy a UHF radio, im thinking about getting one of the good transciever kind.
So i have a scanner aswell, boostcruising i think it is lists all the different areas police frequencies. Would be pretty cool to be able to see what 'they' are upto for once.
Cheapest one is like $300 tho
just need to check my budget status again (mostly current homeloan) and if all goes well i will have the GTR within 2 wks. I currently have one that i have had my eye on for over a mth now. Getting the car inspected this saturday, so fingers Xed.
PS: R33 :rofl:
just have to add i was at bwcp for the last one and got chills when everyone arrived, nothing better then seeing and hearing a line of skylines down shifting down the hill to turn into the car park, i had the r31 for that night!!
Providing I can get my car down here by then( its STILL in Mackay):P I will be there....although i will break the tradition of the round taillights as i still cant find any for sale in japan
We are actually going to make a detour on the way down to stop for hopefully what might be some really good pics.
Hopefully cyrus wont chase rabbits and we won't be scared out by security.
And the rule still stands, be a wanker, your not welcome. Especially at this point in the cruise.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
