hey guys,
So begins my a long journey to be. I was looking around for a r32 for a while as i had had enough of my e30 bmw and it's never ending issues. Saw this come up on carsales one morning and jumped on it 155000 genuine kms, apexi catback with muffler removed, Tein Super Streets, Volk Gtp's, Greddy turbo timer, Gay raceboi momo steering wheel, Cooling pro front mount, hks pod filter, Super cold A/C, Nismo 550cc injectors, gfb valve which i believe is leaking, Picked it up for the handsome sum of $6000 with 6 months rwc and rego, I drove it up from Brisbane Easter sunday.
Man what a trip dropped into limp home mode twice and popped a front tyre. Got home and found 3 boost clamps loose. So fitted 3 new ones and bolted down the hard pipe. While i was looking around found the fuel pump regulator hose was off so there was another boost leak, the charcoal canister lines were also not bolted up. Previous owner was a pilot in training and had no mechanical idea!!!! Car was bogging down from time to time so i pulled the afm and cleaned it and no more limp home mode YAY!!! Car still bogs down from time to time when going from full throttle to part so i'm thinking bov is leaking. So far im loving it. Fitted 2 new 215/45/17 eagle f1's to the front since i had to replace the popped one with a 235 and it was rubbing. So anyway ON WITH THE PICS
https://www.sau.com.au/forums/topic/362853-r32-project-streettrack/
Yeah mate enjoying it so far. Got a few mods planned, getting rid of the hks pod and gettng a apexi dual intake with a cai box. Full service, new pads, new rotors, stainless lines, new coil packs, ebc, new bov, new front pipe/high flow cat and wideband.
Edited by beemae30
Resoldered the afm joints today.... Definetly reccomend it to everyone made a heap of difference. Also stripped the bov wet n dryed it and re lubed it. Helped with the fluttering. Gave it a service with some motul 8100 excess as the old oil was FILTH. New fuel filter and all new fuel hoses. Covered the cross pipe over the radiator with reflective heat tape from work. Don't notice a difference but cleans it up as the old one was tarnished.
Edited by beemae30
Found my cooler was rubbing on my front bar from the shit install job the P/O did. When i pulled it off and had a look i found a lovely suprise. Cooling Pro Coolers ARE SHIT.
IMG_0443.jpg Don't know how u dint an inner fin like that but they did it.
IMG_0442.jpg It leaks oh well solder it up.
IMG_0440.jpg Score 550 yen
IMG_0436.jpg This stuff is awesome
IMG_0435.jpg Awesome tyre fitters
  • 3 weeks later...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
