Recently i have bought a r33 gtst and it has shot spigot bush or input shaft.
The car had its clutch changed at 97.255kms which consisted of the clutch being changed , pressure plate and thrust bearing and also the flywheel was machined.
The car now sits on 118xxxkms and i dont see a point in taking out the gearbox to change the bush if its not serious.
So i was just wondering if its a good idea to ignore the problem or should it be attended to asap and also whats the worst that could happen if its not replaced and something does go wrong?
Thanks Con
https://www.sau.com.au/forums/topic/362941-spigot-bush-or-input-shaft/
Which one is it? they are completely different problems..
Spigot bush sounds like a really high pitched squeal whenever clutch is pushed in (flywheel now turning at a different speed to the input shaft, dry bearing catches). Box out, fit $10 spigot bush.
Input shaft bearing, when mine went, was a pretty severe rythmic thumping when accelerating in all gears. New box or recon.
Tt would be the spigot because everytime i turn the car on the noise comes on about 10 seconds after and when i press the clutch in a little bit or all the way it goes away but when my foots taken off it comes back within 2 seconds
Would you recommend changing it asap or just see how far i can go with it?
If the noise goes away when you put a tiny bit of pressure on the clutch pedal, i.e. pushing until the point where you start to get some resistance from the clutch pedal, then it will be a thrust bearing issue. Noisy thrust bearings are very common in Skylines, particularly if you have an aftermarket clutch. My Exedy clutch used to do it...but a bit of grease sprayed on the input shaft retainer/thrust bearing and it doesn't make the noise anymore. The noise itself isn't much to worry about unless your thrust bearing starts making noise when the clutch pedal is completely pushed in. Unfortunately gearbox has to come out to replace thrust bearing, so maybe try the grease thing or just live with the noise.
it sucks now cos theres no reason to pull out the gearbox other then this stupid bearing. clutch is like new and synchros and bearings are all fine inside the box..
would there be anything else worth changing while im at it so i dont have to take the box out other then if anything goes wrong?
Did you attempt my diagnosis? It may tell you if there is a thrust bearing issue. Gearbox labor isn't something I'd want to pay for if I didn't have to. It coud be as simple as spraying grease on the input shafter retainer and you're going to pull out your gearbox to replace a spigot bearing that may or may not be responsible for it.
There are logical steps to this!
If pulling out your gearbox, replace your clutch arm pivot ball for a Nismo item. They cost about $70, a good investment given how weak the factory item is.
Ive got the same problem (excedy clutch installed 15,000kms ago), although mines gotten to the point where it makes the ticking noise even with the clutch dis-engaged. Also told it was the thrust/spigot bearing and that its not really a problem until it starts messing with clutch feel etc.
Birds - "bit of grease sprayed on the input shaft retainer/thrust bearing". is this accessible from underneath the car? Sorry bit of a noob here.
Thrust and spigot bearing are very different parts. Spigot sits inside the engine block at the end of the crank. Thrust bearing sits on the input shaft retainer and gets pressed up against the pressure plate. Again, if you do my simple test it can often rule out one or the other.
As far as spraying grease goes, that's easy enough, you need to unbolt the slave cylinder...pull off the clutch fork dust cover and shine a torch in there...you'll see the thrust bearing and input shaft retainer. Avoid spraying towards your clutch... you don't need grease in there lol. Put a bit on the clutch fork pivot ball while you're at it.
Clicking when dis-engaging the clutch means the clutch pedal box is broken and it needs to be replaced. You should also change the clutch pedal bracket or upgrade to the nismo one.
If you dont fix this the pedal can snap at the welds on the firewall. Look it up in other threads in this section for more info on it.
My exedy is only 10,000km old and the thrust bearing is noisy aswell. You will never break anything by leaving it noisey.
I'll look into this, and i checked that thread out. Thanks.
  • 1 month later...
Clicking when dis-engaging the clutch means the clutch pedal box is broken and it needs to be replaced. You should also change the clutch pedal bracket or upgrade to the nismo one.If you dont fix this the pedal can snap at the welds on the firewall. Look it up in other threads in this section for more info on it.My exedy is only 10,000km old and the thrust bearing is noisy aswell. You will never break anything by leaving it noisey.
It CAN mean this but can also just be the springs on the clutch plate itself (not an issue). Define "clicking" noise. The broken clutch bracket is more a cracking sound rather than clicking.
Edited by simpletool
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
