  • Replies 77
Wtf...2 of the boys I know got the grouping email but I haven't yet. I entered a week before them...what to do?
Hey Matt,
The email I got with the grouping has a phone number at the bottom. Try 5766 4235 and see if you can get through to Adam.
Cheers
Good times peeps :thumbsup:
Hey Jack...too embarrassed to run the emo under SAU were you ;) How did you find the emo compared to the real race car?
LOL, not at all mate, just happened to be good timing to attend this trackday at Winton...
Well what a day! Was worried about the weather but it turned out to be a nice sunny day, until the clouds came in at about 1pm and the temperature dropped considerably, rain held off though. Was good to catch up with Troy, Matt (femno) and crew, Martin (emts) and John (ssxRicho). Congrats to all as I'm sure everybody got a PB today.
Was quite anxious really to see how the Emo would go, especially since I've only driven it around the block near my house as it isn't registered, so today was a day to get out there and drive the car in anger for the first time. After spending quite a bit of time in the last 3 weeks getting the car ready it was time to see what it could do.
To say I'm impressed is an understatement. I was aiming just to get used to the car as I have never driven an Emo before, so would have been happy with a 1:38.
So to end up with a 1:35.5 I guess I could not ask for more, especially since the car has a standard motor with standard turbo running 219awkws on e85. I wanted to concentrate on the handling so some Tein Ra's were thrown at it together with a Whiteline rear sway bar. Setup the wheel alignment settings and heights and that's pretty much it. Got some 2 piece project mu used rotors and some new pads and the brakes didn't miss a beat all day.
In all seriousness for the money I've spent it's much better value than what I've spent on the GT-R. Emo's are highly under estimated and are a lot of fun around a track like Winton. I do suspect though at Sandown it won't come near the GT-R, power falls over after 6500rpm.
All in all a fantastic little car and look forward to seeing how far I can push it with current mods...
No doubt Winton is heaven for EVOs, but a good car punted well will be quick everywhere! They do look mint in silver, and to think it was havinga ew problems but was still so quick. Even with only 2L you put me into the shade :) But I was louder...thats all that is important
and with a damn nice note to boot Troy. Glad to see you actually got to enjoy the thing for the whole day.
Had a fantastic day taking 1s off my PB in the cars second outing. Admittedly i dont mind the RWD or lack of front wheel driving force :ninja:
Jack pulling that time in your first outing is just plain silly.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
