It's a genius piece of design, actually :rolleyes: .
Half mounted to the body and half to the rubber bushed subframe; that way you can gradually tear out half of the boot floor, then have your trailer spear off into the bushes still attached to the rear suspension of your car.
Which is now not attached to your car anymore...:thumbsup:
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5797466
I had mine fitted there too via Japlink Motors when I purchased the car.
BTW, I was in there today as my indicators don't work when the trailer is connected. all other lights work fine.
Apparently, the trailer requires LED lights so as not to draw too much current. Not sure whether this is true or not.
Sorry, my bad; Leichardt, not Chatswood,:blush: as both you & Andy said.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798099
Rosella, I had EXACTLY the same problem as you're describing on my trailer; replaced with LED's, SOLVED!
I'll shoot you a link tonight, and you can check out the ones I got, good price, nice quality. If you like, bring em down & I'll sort it for you.
Cheers, Dale.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798131
Cheers, Dale.
I already had LED's on my trailer so never had a problem.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798134
Drove me bezerk, I can't tell you how stoked I was when I replaced the crappy, bayonet style lamps, and the blinkers finally worked.
It must just be a resistance issue.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798174
I'm pleased I can get it sorted.
Andy, you're lucky to find a trailer with those kind of lights. The manufacturer of my trailer doesn't even have a computer so there's no way was he going to have LEDs for the lights. :spank:
Dale, I had to resort to hand signals. Brings back memories....:yucky:
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798254
  • 1 year later...
There seems to be a fee topics on this with no real useful info.....
I've scouted these forums and found only 1 company in Sydney (fast fit) that will do towbars for M35's , I wasnt really happy with a 3hr fit job and a 1200kg bar
I end up using south coast towbars @ Unanderra
Cost $700, bar is custom made. And the work is great! Took a day and a bit to complete, Tongue sits nice and heigh so my trailer is nice and balanced on the ball. Rated at 1500kg
Highly recommended. It's a 1 man shop
So the service is ace.
Btw, you may read that towbars cause rear sub frame cracking... That's just not true, there is no way any bar install will go near the rear subframe
Myth busted!
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-6402012
Subframe crack was never about the actual tow bar being mounted there. Thats a no-brainer. Its about weight distribution. More weight / load will inevitably go through the rear suspension, and thus, the subframe.
Feel free to load up with 1500kg, and drive a five thousand kms.
Then pronounce the myth busted.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-6402016
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
