It's a genius piece of design, actually :rolleyes: .
Half mounted to the body and half to the rubber bushed subframe; that way you can gradually tear out half of the boot floor, then have your trailer spear off into the bushes still attached to the rear suspension of your car.
Which is now not attached to your car anymore...:thumbsup:
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5797466
I had mine fitted there too via Japlink Motors when I purchased the car.
BTW, I was in there today as my indicators don't work when the trailer is connected. all other lights work fine.
Apparently, the trailer requires LED lights so as not to draw too much current. Not sure whether this is true or not.
Sorry, my bad; Leichardt, not Chatswood,:blush: as both you & Andy said.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798099
Rosella, I had EXACTLY the same problem as you're describing on my trailer; replaced with LED's, SOLVED!
I'll shoot you a link tonight, and you can check out the ones I got, good price, nice quality. If you like, bring em down & I'll sort it for you.
Cheers, Dale.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798131
Cheers, Dale.
I already had LED's on my trailer so never had a problem.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798134
Drove me bezerk, I can't tell you how stoked I was when I replaced the crappy, bayonet style lamps, and the blinkers finally worked.
It must just be a resistance issue.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798174
I'm pleased I can get it sorted.
Andy, you're lucky to find a trailer with those kind of lights. The manufacturer of my trailer doesn't even have a computer so there's no way was he going to have LEDs for the lights. :spank:
Dale, I had to resort to hand signals. Brings back memories....:yucky:
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-5798254
  • 1 year later...
There seems to be a fee topics on this with no real useful info.....
I've scouted these forums and found only 1 company in Sydney (fast fit) that will do towbars for M35's , I wasnt really happy with a 3hr fit job and a 1200kg bar
I end up using south coast towbars @ Unanderra
Cost $700, bar is custom made. And the work is great! Took a day and a bit to complete, Tongue sits nice and heigh so my trailer is nice and balanced on the ball. Rated at 1500kg
Highly recommended. It's a 1 man shop
So the service is ace.
Btw, you may read that towbars cause rear sub frame cracking... That's just not true, there is no way any bar install will go near the rear subframe
Myth busted!
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-6402012
Subframe crack was never about the actual tow bar being mounted there. Thats a no-brainer. Its about weight distribution. More weight / load will inevitably go through the rear suspension, and thus, the subframe.
Feel free to load up with 1500kg, and drive a five thousand kms.
Then pronounce the myth busted.
https://www.sau.com.au/forums/topic/363197-towbar-for-m35/#findComment-6402016
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
