Hey guys heres my build plan would this be adequate just for using as a street car:
RIPS RB30 Stock internal bottom ends, with RIPS modifications, fully refreshed
Standard R33 RB25DET VCT head *is there any modifications needed or just bolt on?*
R33 GTST PFC with boost controller kit
Yellow Jacket ignition coils
Walbro 255l Fuel pump
GTR intake plenum with 700cc injectors
HKS 3037 Pro S turbo *should i go bigger to a GT35R?*
Items in consideration:
Nitto Oil pump
Enlarged Sump
Cheers
Chi
https://www.sau.com.au/forums/topic/363243-rb30-build/
Sounds 'adequate' to me for a street car haha.
There is heaps of info in the stickies above on what mods are required to get the twin cam head onto the rb30 bottom end.
Only comment I will make is that if you choose the 3037 then make sure you get the larger 0.87 housing if possible. I would recommend either a kando T67 or a 3076 with 0.82 housing. For a street car I would leave the GT35R alone.
You might as well go larger injectors to give yourself more headroom and if you ever decide to run E85. I would go ID1000's. Not sure whether that fuel pump will be enough.
Will you be using standard exhaust manifolds?
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5796770
The head bolts on but you can weld up/ block the VVT oil feed and shape the water gallery next to it and shape it to suit the rb30 water jacket. If you dont then there is approx 1mm of sealing area around that water jacket.
Go the 35R, the difference in price is nothing for the extra increase in power, you will be wanting more when u max out the 3037
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5796955
the 26 plenum i have a blitz adaptor plate kit for it to be bolted on mmmm I think the RIPS 30 block has all the modifications so the head is to be bolted on without having to block the VCT oil feed etc ill email RIPS about this, exhaust manifold wise if i get a GT35R i will be going a 6boost manifold. but is the nitto oil pump needed?
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5796982
iirc it has an external feed set up. theres no way of doing it without blocking the original feed, as it overlaps with a water gallery on the 30 block. the other way thats on here is to feed vct oil from the cam buckets by drilling out a brass fitting in the head
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797002
I disagree, there is car on here (Al's) with an RB2530, he runs a GT3076 0.82 and makes 330rwkw with unbelievable response.
My argument is that I would prefer a super responsive ~330rwkw setup then a less responsive ~370rwkw setup for the street. It depends on the driver too on what they prefer.
I have just changed from a 280rwkw setup on an RB25 with less reponse and changed to 250rwkw with amazing response and it would beat the previous setup in all times but a rolling start from 80+ km/h
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797416
At 378rwkw I have no lag with a GT35R .82
Edited by Alf
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797916
Wow you just created the first turbocharged vehicle to not have lag!!!
I think you mean the lag you have is acceptable for you. Put the car in 5th gear at 60km/h and tell me you have no lag.
Im almost there with that feat! :D
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797985
lol. ahhh it would appear I did...:whistling:
But to get back on point, the most responsive our race car ever was, was when it had a gt30 on it. Exact build spec was standard head and valves with tomei stage 1 cams retaining the vct, 6boost manifold with gt30 with .82 rear, 8.2:1CR and we were making 320rwkws. Then when we put a water methanol setup on it it bumped upto about 360rwkws and it was amazing! Pulled like a steam train but used to die off abit early up high.
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5799441
Exactly, what speed did it die off up high? I am tipping way above legal road speeds. Why such low compression??
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5800060
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
