Ok guys, the weekend of the 4-6th June might be a go, with the day being either on the sunday or monday.
I'm in the process of finding out the schedule for the next month or so, so the final date is TBA.
Watch this space!
Two weeks to get the car going and tuned.. I might be pushing it!
  • Replies 69
Sunday 12th June?
This is looking like a good day to do it.
I've had word that the venue is available, but I need to confirm the day/date soonest, so that no one else books it.
There will be 13 spots.
Post your replies here ASAP...
^^ Same here. I started my new job just after they pay us (get paid monthly) so I have to wait a few weeks before I get my first pay and I'm literally dead broke at the moment. :(
The 12th of June is confirmed.
Cost will be $140 per driver, and will include a bbq lunch and drinks
I will paying in full before the day, so you will be paying me back directly.
There are 18 places in total, with 5 already allocated.
First come, first served.
Post your definite intentions to participate below...
It will be an Autokhana/Superkhana style event, which essentially means driving really fast around a series of tight corners and short straights.
It will be a FULL day event, but obviously you can come and go as you please.
You will need your own, or access to the following things;
  • Licenced & roadworthy car
  • Helmet
  • Long sleeve shirt and pants (cotton is best)
  • Closed in shoes
Your car will be lightly scrutineered before you are allowed to drive it on the track.
Basically, make sure the following things are done;
  • Battery is secure
  • Seatbelts lock under tension
  • Tyres are not completely bald
  • Loose objects are removed from cabin
  • Your car is not falling apart
  • Your car is not leaking vital fluids
Cost is $140 - payable before the day.
Price will include Hot Dogs and drinks for the drivers only.
Spectators are most welcome, but will need to provide their own food and drink.
You will need to bring your own;
  • Seats/blankets/cushions to sit on during the day.
  • Sunscreen, just in case
  • Insect repellent, just in case.
  • Don't forget your tools, and spares just in case!
There's plenty of room to make a mistake, so rest assured that the worst that will happen is your car might get a little dirty.
It'll be good fun, and it'll be at mostly slower speeds, so drive at the pace that you're most comfortable with. Your times will improve the more you drive.
There's a chance of some professional instruction on the day too.
The money is non-refundable, so if you can't make it, find someone else to take your place.
Make sure your car is reliable, and will last the whole day. The price is the same whether you drive for 1 run or 20.
You may drive someone else's car (with their permission of course!), but that car will need to scrutineered also if it hasn't been already.
Lastly, the track is for everyone who is driving on the day. Each run takes about 1 minute 30 seconds.
Don't dawdle, remember who you're after in the running order, and standstills are for Motorvation.
If you're deemed to be unsafe on the track, you get 1 warning only. After that, no more driving for you.
You will need to let me know via PM or e-mail, if you intend on driving by 5pm this Thursday the 2nd of June, so that I can advise and pay the venue, and sort out your running order for the day.
Contact me with any questions
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
