Hey guys,
As above, when changing from Drive to Reverse and vice versa, the car jerks, also when driving the car it doesn't change gears smoothly, it does a little jerk.
When I went to pickup my spare key from Nissan, I asked the Mechanic and he said the timing belt was probably spinning too fast, but doing some research online, most seem to say it's either the Transmission Fluid or bad gearbox (Which I am dreading).
I was just going to wait until the next service, but thought I would ask you guys first.
Cheers
https://www.sau.com.au/forums/topic/363528-car-jerks-when-changing-gears/
Hey guys, sorry for the late response, I checked it before, while the engine was running, and warmed up and on a level surface, it seems to be between the highest hump on the stick and the top of the crosshatches, so it's a little over, but I noticed every time I pull it out, there are little bubbles on it?
Also what color should it be, it looks darkish.
EDIT:
Would having too much fluid cause the transmission to slip?
I read if there is too much it will cause the fluid to foam up?
There aren't many bubbles on the dipstick, like 1-4 little ones, but it could still mean the fluid is foaming up yea?
Edited by Converge
Ok, I think there is definitely too much transmission oil, I let the car sit out side for a good 3 hours before, engine was cold to the touch, took the dipstick out and it was nowhere between or on the crosshatching, it goes way past it on the cold side and even the hot side, where the crosshatching is further up.<br><br>But would this cause the transmission to slip/make the car jerk?
Edited by Converge
What was the verdict?
Was going to make a post about it before, but didn't think anyone was interested, so didn't bother.
But anyway, I went to a few places, was a bit odd, 1 said it was perfect, just on the line and the other said it was a little bit over, they did recommend me to get it serviced as the fluid looked pretty dark (Should be Pink to almost clear), so I will drop it off this week sometime to get it flushed. Hope it fixes the problem, but not going to get my hopes up. :(
Will report back later this week?
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
