lol, it kept telling me the post didn't work!! I tried it a couple of times with no apparent sucess and went to bed last night thinking it had failed :rant:
I'll give the guy painting the wheels a call Monday or Tuesday, but the 8th could be cutting it fine.
Im after another trans cooler or a 25 to 30 row oil cooler that I can run with a fan to keep the auto cool.
Let me know what you have got
This is what you are after Rob. I'd much rather spend a bit more and get a brand new one, that way you know it isn't chockas with shit
http://www.ebay.com.au/itm/B-M-HI-TEK-TRANSMISSION-OIL-FLUID-COOLER-W-ELECTRIC-FAN-/360405477020?pt=Motors_Car_Truck_Parts_Accessories&hash=item53e9d7269c
I'm getting the woman's R33 on the road, I'm after a few random things people might have from popped engines/upgrades?
Stock S1 coil packs (need to be good for 12psi) or cheap after markets
RB20/25/30 Harmonic Balancer w/AC (pref no dents/chips)
Tensioner and Idler pulleys, non rattly (mine were seizing)
The bolt (and if possible 2 washers) that go with the t-belt idler pulley
And just for my R33, a split dump pipe, either just the top/front section or all the way to cat, as I have a stock front pipe with 3" dump and am trying to fix slight over-boosting.
Just PM me! Cheers
-Dan
Just PM me! Cheers
-Dan
i would have a ballancer and im coming down to hobart this weekend if you want it.
The 32 with a carbon bonnet is Xrated i think. I used to drive a blue 31 with s13 wheels. Had a white 31 parked out front for ages. Been stuck driving the shitty VN wagon, the D21 Navara and the missus 04 Corolla. Soon i'll be getting about in my Black over grey 31 Coupe though.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
